It is currently Fri Jan 24, 2020 8:32 am
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Sun Sep 08, 2019 4:45 pm
When I try UPDATE PFC200 runtime in codesys I get error:
[INFORMATION] Executing SSH command on root@192.168.1.100: Stop runtime
[INFORMATION] Executing SSH command on root@192.168.1.100: Package: store existing cfg file
[INFORMATION] Executing SSH command on root@192.168.1.100: Package: remove old
[INFORMATION] Executing SCP command on root@192.168.1.100: Package: transfer new runtime
[INFORMATION] Executing SSH command on root@192.168.1.100: Package: install new runtime
[ERROR] Error output: tar: Removing leading `/' from member names
[INFORMATION] Standard output: Installing codesyscontrol (3.5.15.0) to root... create backup of wbm Installing codesyscontrol (3.5.15.0) to root... Installing codesyscontrol (3.5.15.0) to root... Configuring codesyscontrol Backup licenses Starting plc /root
Successfully terminated.
What can be wrong with my runtime update on PFC200 ?
PostPosted: Sun Sep 08, 2019 6:34 pm
I would check this:
viewtopic.php?f=24&t=9950#p25145
maybe there is no space left on your device ( if multible CODESYS runtime version applied?)
check by ssh login and
df
PostPosted: Mon Sep 09, 2019 8:21 pm
It is may df command result:
PostPosted: Mon Sep 09, 2019 8:26 pm
When I restore FW to default wersion the home webpage is WAGO. When I run my Codesys v3.5 and choose UPDATE PFC200 it is installed and above error but it is works...I'm only worried about this error, because I try for several days run SMS service and it doesnt work.
Do you know what can be wrong ?
I bought codesys sms service library, I run example project (only change target to PFC200) and set like this documentation:
PostPosted: Mon Sep 09, 2019 8:28 pm
And I have still problem with initiation my modem :
PostPosted: Tue Sep 10, 2019 6:27 am
I think there is a change in newer the new Wago firmware of the PFC and which CODESYS version are you using?
(3.5.15.0?)
Could you add a bug report to the CODESYS store -> my question -> bug support
This need to be changed/adapated either in the example/dokumentation....
PostPosted: Tue Sep 10, 2019 8:04 am
Yes, I use 3.5.15.0 version.
I added bug report , I am waiting for response .
PostPosted: Tue Sep 10, 2019 8:15 am
and which Wago firmware is on this device?
(Check with the WBM or cbm)
PostPosted: Tue Sep 10, 2019 8:34 am
Now I do not access to PFC200, in 6 hours I will have , but yesterday I installed the this firmware :
ftp://pfc200:pfc200@212.160.183.43/WAGO ... _r40667.7z
PostPosted: Tue Sep 10, 2019 7:20 pm
It is may FW version:
PostPosted: Wed Sep 11, 2019 10:15 am
i have send out an email:
either manually for a test:
ln -s /dev/ttyMdm0 /serial3
(for Com4) set
or to have it fix after reboot in
/etc/rc.d/S01_link_devices
Set GSM_MODEM_TTY_PFCXXX_LINK_NAME="/dev/serial3"
Guess this will work in case the firmware of the modem is still the same. (cross my fingers for this)
