It is currently Mon May 20, 2019 11:59 pm
PostPosted: Sat Jan 20, 2018 11:54 am
Hi there,
I developed a CODESYS 3-IO driver for the Monarco Hat by Monarco.io. A SPI based Hat device for the raspberry Pi.
The .package file is too big, so I decided to post a link to my git where you can find it.
Implemented as CODESYS 3 IO device-driver;
Open source,
Pure IEC code (ST).
No function block calls in your software necessary, just write code, attach variable to an I/O channel, ready!
Breaks compatibility with earlier FB version but improves highly on ease of use,
4 Di,
4 Do,
2 Ai,
2 Ao,
Hardware Watchdog,
Control Byte (experimental).
Stable, but work in progress ...
Also, other CODESYS 3 goodies can be found there, leave a comment ;-)
https://github.com/Aliazzzz/
With kind regards,
Aliazzz
https://forge.codesys.com/u/aliazzz/profile/
(Scroll down for my projects)
PostPosted: Sun Feb 11, 2018 5:57 pm
PostPosted: Sun Jun 24, 2018 9:33 pm
Codesys Application Composer "FirstSteps" Example implemented with the Monarco V2.0.0.0 Library;
https://github.com/Aliazzzz/Monarco-HAT-library-for-CODESYS-V3/tree/master/Monarco/FirstSteps
