It is currently Sun Feb 23, 2020 2:09 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 43 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Apr 29, 2016 4:45 am
Autor: alecudr
viewtopic.php?f=21&t=6884
PostPosted: Wed Oct 19, 2016 6:22 pm
Google Maps Application in Webvisu
New:
googlemaps_ext1.js
Line 395 set 'TODOSETKEY' with GOOGLE API KEY
How to get an API KEY https://developers.google.com/maps/docu ... et-api-key
 Post subject: Webbrowser Element
PostPosted: Sat Nov 05, 2016 7:11 am
Example for using the Webbrowser Element
PostPosted: Wed Nov 30, 2016 5:33 am
Check the if license is activated on Runtime KEY and SoftLicense!
PostPosted: Wed Nov 30, 2016 5:46 am
Imported CODESYS V2.3 Project Example
PostPosted: Wed Jan 04, 2017 7:55 am
In this project eth1 interface is used for the profinet connection to the ProfinetMaster
you need to add in /etc/CODESYSControl.cfg (Version <3.5SP12)
>= 3.5Sp12 /etc/CODESYSControl_User.cfg
[SysSocket]
Adapter.0.Name="eth1"
Adapter.0.EnableSetIpAndMask=1
and execute in the Linux console
<3.5Sp13
ifconfig eth1 promisc
das in /etc/rc.local einbauen
If you use a Pi3B+ you Need the following steps:
Using VLAN-Tags Need to be enabled:
sudo apt install vlan # install VLAN-Packet
sudo modprobe 8021q # load 8021q Kernelmodul
for having this in every Startup automatically:
sudo su -c 'echo "8021q" >> /etc/modules'
PostPosted: Wed Jan 11, 2017 5:24 am
Read the onewire sensor in an own onewire Task / scan connected sensors
Rescan while running is possible by reset - x
IF NOT x THEN
x := TRUE;
//scan function
Onewire_master.Scan();
FOR ui:=1 TO MIN(Onewire_master.uiScannedDevices, 20) DO
astrID[ui] := Onewire_master.pasScannedDevices^[ui-1].StringRepresentation;
//dynamic write the scanned sensors to the configuration
DS18B20.ID := Onewire_master.pasScannedDevices^[ui-1];
END_FOR
END_IF
actDate := DS18B20.stdTimeStamp;
SysTimeRtcConvertDateToUtc(actDate,dwActDate);
dtTimestamp := DWORD_TO_DT(dwActDate);
PostPosted: Fri Mar 03, 2017 6:22 am
Communication - 2 Raspberry PI Modbus TCP
PostPosted: Tue Mar 07, 2017 6:00 am
Using OWFS to read onewire
Which device is used on this example
1-Wire Busmaster / USB Hostadapter DS9490R, Eco-Line; Art-Nr: 0167
Important links to bring it up:
DS9490R:
http://pdfserv.maximintegrated.com/en/d ... S9490R.pdf
http://owfs.org/index.php?page=usb-ds9490r
Info and wiring (Parasitic Power):
https://shop.wiregate.de/1-wire-bus
Installation:
https://www.raspberrypi.org/forums/view ... 9&p=505250
additional Infos:
https://www.fischer-net.de/hausautomati ... eil-2.html
PostPosted: Thu Apr 06, 2017 7:25 am
Raspberry Pi communication with Ethernet /IP Scanner and Adapter
PostPosted: Mon Sep 25, 2017 8:17 am
Reading RFID's with an USB RFID reader.
(KKmoon Berührungslose 14443A IC Kartenlesegerät Kartenleser Card Reader mit USB Schnittstelle )
(Webvisu is mandatory for doing this - we use the visu key Event handling)
 Post subject: Sonos
PostPosted: Sat Nov 25, 2017 6:19 pm
Author: TON
Communiction with Sonos speakers
Program made with:
- PlayBar (Woonkamer)
- PLay 1 (Left)
- PLay 1 (Right)
- Sub (Subwoofer)
- Play 3 (Keuken)
- Play 1 (Badkamer)
- Play 1 (Slaapkamer)
Uses UDP socket for upnp Discover, TCP Server for events and TCP Client for commands.
Visualization for each group.
Display play status each group.
Control Play, Pause, Next, Previous each group.
Control Volume and Mute for each player.
See property each speaker by dialog.
Max 10 groups, 10 speakers with 3 satellites(LR, RR en SW).
Play doorbel
Functions:
- Find Sonos players with upnp discovery
- Find correct local ip if more then one network adapters
- Subscribe/Unsubscribe upnp events
- ZoneGroupTopology (for enumerate groups)
- AVTransport (get actual play status)
- RenderingControl (get volume/mute)
- Get XML player info
- Dialog box to display player info
- Webvisu. http://xxx.xxx.xxx.xxx:8080/webvisu.htm
 Post subject: Push notification
PostPosted: Sun Nov 26, 2017 5:49 am
Author: TON
Push notification to Android/ios/desktop withPusover.
https://pushover.net/.
Push notification to your device with title, message, sound and application.
For $5 (once) you can push 7500 notifications per month.
With this account you can create notification for applications.
This application has name, token, icon,.. So you can create a clear structure.
In this example you see a notification for three applications.
I use this for over a year and works like a charm.
I just use some of the possibilities, there a more. See https://pushover.net/api.
PostPosted: Wed Dec 20, 2017 2:16 pm
Using an opcua python client for communcation with plc symbols (either on the same PI or remote PI)
How to use it:
1. Install OPCUA python:
sudo apt-get install python3-lxml
pip3 install opcua
2. download CODESYS Project to the Pi and start it:
Use the OPCUA Project from the Pi examples
"c:\Users\<WindowsUserName>\CODESYS Control for Raspberry PI\3.5.12.0\Examples\OPCUA.project"
Sample Python OPC UA Client.py example for browsing the variables/symbols
PostPosted: Thu Dec 21, 2017 8:02 am
This is an example using the Unicorn HAT:
How to add python script and download them to the Pi and execute them on the PI.
https://www.youtube.com/watch?v=R9x-QX2 ... e=youtu.be
