It is currently Thu Jan 17, 2019 8:42 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Sun May 28, 2017 6:23 am
Author: Dag H. Hanssen
Date: 09.05.2017
Here is a library I made for the device LSM9DS1, an Accelerometer/Gyro/Magnetometer form ST life.augmented, on a break-out board from Adafruit. (I had to zip the library-file since the size was more than 500kB, which is maximum upload file-size for this forum.)
The device has actually two slaves, but I chose to integrate them both with on device-description. It doesn't matter if the user assigns a slave address in the project, the code in the library alters anyway between two different slave-addresses when writing/reading data.
Though the device has built-in FIFO-registers, for faster and less time-/power-consuming readouts, I have not used this option in this version of the library. Instead, the readout is timer-controlled, with a user-specified read-rate.
I have also uploaded a very simple test-project.
Hope someone finds the library useful,
Dag Hansa
PostPosted: Sun May 28, 2017 6:31 am
Autor: raymondclark0
Date: 09.05. 2017
Version: 1.1.0.0
My Library for the ST LSM303 accel magnetometer board avaliable from Adafruit.
Separate device files, but combined library.
Attached is an example project too.
Thanks,
Ray.
PostPosted: Sun Nov 26, 2017 6:04 am
Autor: Stefan2
Date: 17.11. 2017
Version: 1.0.0.0
Here is my Library for some I2C devices for CODESYS.
You can place all devices behind a multiplexer to reduce address conflicts.
Although include the BME280 Environment sensor and an SD1306 Display Driver.
Look at google for these little funny Displays.
All fonts are working on the display, but not the biggest. There the bits have to be twisted.
If you find any problems, tell me, the Drives have not been tested all.
Don't look at the documentation, there is none ... ;).
In the I2C_Base FB I did write some info’s for the muxing.
With the muxing IC you can connect about 33554432 BME280 on the raspi, but then bus cycle time is no longer a problem ;).
You will need the OSCAT building lib to compile. i can not uplode it here like the OSCAT BASIC lib(to big), so try the lib from the store.
Device list:
BME280
25C512 64KiB EEPROM
An 4channel dimmer (I done this for an friend)
PCA9555 as 16 bit input
PCA9555 as 16 bit output
PCA9685 a 16 channel 12bit PWM output, inspired by example code of CODESYS but writes only when output value is changing
PCF8575 as 16 bit input
PCF8575 as 16 bit output
SSD1306 Display Driver
TCA9548 8 channel I2C Multiplexer/switch
https://github.com/stefandreyer/I2C-Multiplex
TSL2561 lux sensor, state I would say experimental
Greetings Stefan
PostPosted: Thu Dec 13, 2018 8:44 am
Autor: johan76swart
Date: 25.07. 2018
Version: 1.0.0.0
Hello fellow Raspberry enthusiast!
Here is a device library for the MCP4728 4-Channel 12-bit DAC, default address = 0x60.
Input an integer 0-4095 for each channel.
 Post subject: MQTT library
PostPosted: Thu Dec 13, 2018 8:52 am
I did implementing an MQTT library, test it an have fun…
Greatings
Short info from short doku...:
please start here:
PostPosted: Thu Dec 13, 2018 9:01 am
Autor: Aliazzz
Date: 11.02. 2018
Version: 2.0.0.0
Monarco.io
Codesys Application Composer "FirstSteps" Example implemented with the Monarco V2.0.0.0 Library;
https://github.com/Aliazzzz/Monarco-HAT ... FirstSteps
