It is currently Tue Dec 18, 2018 3:51 pm
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Dec 21, 2017 10:45 am
This example shows how to use a port-expander PCF8574 I2C without library/device description
from the application code.
Control Christmas lights:
https://www.youtube.com/watch?v=6vsxV-Bj6-4
PostPosted: Wed Mar 07, 2018 6:54 am
Demo Project for VisuUaserManagement, show statistic who is logged in,
Change logged in user by iec code.
PostPosted: Tue Mar 13, 2018 11:48 am
Using enocean with the Raspberry Pi
See:
https://youtu.be/mYaqMY8ddAk
PostPosted: Wed Apr 25, 2018 10:41 am
How to use IO-Link devices with Ethercat and Gateway EL6224
https://www.youtube.com/watch?v=GadTtFrnUEc
PostPosted: Fri Sep 07, 2018 12:47 pm
Play Sound on Raspberry PI. PiFace Interface is used.
RaspiSound_nonblocking Play several sound on the same time.
It uses the Omxplayer, should be installed.
Original post:
https://forum-de.codesys.com/viewtopic. ... 723#p18206
PostPosted: Fri Oct 19, 2018 7:44 am
Login by ssh to the PI:
dmesg | grep -i tty
to check which serial interface is available / connected
1. remove ';' /etc/CODESYSControl_User.cfg in the section [SysCom] and adapt ttyS to your used device
for example if you use USB which is connected to USB0 then it should /dev/ttyUSB in this config file
[SysCom]
;Linux.Devicefile=/dev/ttyS
2. If you use the serial port which is on the GPIO's (3.3V!) then you need to enable it in
sudo raspi-config ( Interface options - login shell disabled and serial hardware enabled)
3. User https://store.codesys.com/serial-com.html as example on how to use the serial port in CODESYS
PostPosted: Sat Nov 10, 2018 8:05 am
even on Pi this is not really needed,
you could use on Raspian Stretch and use Chromium in full screen mode - this feels then similar to
targetvisu.
how to do this?
Add a CODESYS Project with webvisualisation and then:
Target VIsu is not possible but a good solution is on Rasbian(not Rasbian lite):
sudo nano /home/pi/.config/lxsession/LXDE-pi/autostart
or
sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
(depends on the installed RASBIAN Version)
lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@xscreensaver -no-splash
@point-rpi
@xset s off
@xset s noblank
@xset -dpms
@chromium-browser --noerrdialogs --kiosk --incognito http://localhost:8080/webvisu.htm
PostPosted: Thu Dec 13, 2018 8:38 am
CmpCharDevice snippet
