It is currently Thu Oct 19, 2017 11:45 am
Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page Previous 1 2
PostPosted: Fri Apr 29, 2016 4:45 am
Autor: alecudr
viewtopic.php?f=21&t=6884
PostPosted: Wed Oct 19, 2016 6:22 pm
Google Maps Application in Webvisu
 Post subject: Webbrowser Element
PostPosted: Sat Nov 05, 2016 7:11 am
Example for using the Webbrowser Element
PostPosted: Wed Nov 30, 2016 5:33 am
Check the if license is activated on Runtime KEY and SoftLicense!
PostPosted: Wed Nov 30, 2016 5:46 am
Imported CODESYS V2.3 Project Example
PostPosted: Wed Jan 04, 2017 7:55 am
In this project eth1 interface is used for the profinet connection to the ProfinetMaster
you need to add in /etc/CODESYSControl.cfg
[SysSocket]
Adapter.0.Name="eth1"
Adapter.0.EnableSetIpAndMask=1
and execute in the Linux console
ifconfig eth1 promisc
das in /etc/rc.local einbauen
Attention in 3.5.10.0 accidentally the PNDevice license is not included, this will be solved to the next version.
PostPosted: Wed Jan 11, 2017 5:24 am
Read the onewire sensor in an own onewire Task / scan connected sensors
Rescan while running is possible by reset - x
IF NOT x THEN
x := TRUE;
//scan function
Onewire_master.Scan();
FOR ui:=1 TO MIN(Onewire_master.uiScannedDevices, 20) DO
astrID[ui] := Onewire_master.pasScannedDevices^[ui-1].StringRepresentation;
//dynamic write the scanned sensors to the configuration
DS18B20.ID := Onewire_master.pasScannedDevices^[ui-1];
END_FOR
END_IF
actDate := DS18B20.stdTimeStamp;
SysTimeRtcConvertDateToUtc(actDate,dwActDate);
dtTimestamp := DWORD_TO_DT(dwActDate);
PostPosted: Fri Mar 03, 2017 6:22 am
Communication - 2 Raspberry PI Modbus TCP
PostPosted: Tue Mar 07, 2017 6:00 am
Using OWFS to read onewire
Which device is used on this example
1-Wire Busmaster / USB Hostadapter DS9490R, Eco-Line; Art-Nr: 0167
Important links to bring it up:
DS9490R:
http://pdfserv.maximintegrated.com/en/d ... S9490R.pdf
http://owfs.org/index.php?page=usb-ds9490r
Info and wiring (Parasitic Power):
https://shop.wiregate.de/1-wire-bus
Installation:
https://www.raspberrypi.org/forums/view ... 9&p=505250
additional Infos:
https://www.fischer-net.de/hausautomati ... eil-2.html
PostPosted: Thu Apr 06, 2017 7:25 am
Raspberry Pi communication with Ethernet /IP Scanner and Adapter
PostPosted: Mon Sep 25, 2017 8:17 am
Reading RFID's with an USB RFID reader.
(KKmoon Berührungslose 14443A IC Kartenlesegerät Kartenleser Card Reader mit USB Schnittstelle )
(Webvisu is mandatory for doing this - we use the visu key Event handling)
