It is currently Thu Nov 21, 2019 12:36 pm
PostPosted: Tue Sep 03, 2019 12:04 pm
If its possible to start linux programs from
Quote:
SysProcess.SysProcess.ExecuteCommand2
function?
Simple command like
sudo reboot
is working but when I try to use program
Quote:
netcat
then nothing happen. Even when I create script with netcat command and I will run this script from codesys its not working. When I run this script from shell its working properly.
This is some codesys limitation or I am doing something wrong?
Somebody try to start any linux program from codesys?
PostPosted: Wed Sep 04, 2019 9:45 am
hm.. looks like a bug,
I see if I add the command to /etc/CODESYSControl_User.cfg:
[SysProcess]
Command.0=shutdown
Command.1=netcat
and start the runtime manually ( to have more debug info), we see that netcat is executed, anyway somehow the result is not delivered to the SysProcessCommand2 in the IEC code.
Seems a to be a bug.
Please add a bugreport with your application attached to the store -> my question -> bugreport
PostPosted: Wed Sep 04, 2019 10:12 am
Thank you for your response.
How do you get this debug info?
Can You try command
Quote:
"echo message `date +%s` | nc -u -w 0 192.168.1.1 2000"
This should send UDP message "message `date +%s`" to 192.168.1.1 on port 2000.
In Your test program netcat was executed, but I cant send UDP message.
If somethisg is not clear feel free to ask.
PostPosted: Thu Sep 05, 2019 7:49 am
not sure what exactly you want to archive but I would recommend to send or receive UDP frames
that way:
viewtopic.php?t=6625#p13743
PostPosted: Thu Sep 05, 2019 8:14 am
In Your test program netcat was executed but the result was not delivered to the SysProcessCommand2 in the IEC code.
Can You test again program netcat to for example send some UDP packet, it will be for shure that it was executed properly or not.
When I try command
UDP packet is not sended, probably netcat with this parameter is not executed.
Can You explain how to run this debug mode from previous post?
In CODESYSControl_User.cfg I have:
[SysProcess]
Command=AllowAll
PostPosted: Fri Sep 06, 2019 8:12 am
I think it is not allowed to combine commands / echo + netcat
stop the service by:
sudo /etc/init.d/codesyscontrol stop
start it manually by
cd /var/opt/codesys
sudo /opt/codesys/bin/codesyscontrol_armv6l_raspberry.bin -d /etc/CODESYSControl.cfg
Once again I would recommend to do this UDP sending stuff by netbase services library like in the link in the upper post.
