It is currently Tue Feb 18, 2020 1:19 am
PostPosted: Mon Aug 05, 2019 9:06 pm
Hi There,
I have had this issue several times now and it frustrates me more and more!
I have a working Raspberry Pi 3B+ with a CODESYS USB dongle and a Raspberry Pi SL.
I did a fresh install of Raspbian Buster Lite and ran Raspi-Config to enable SPI, 1 wire, serial COM,i2c and Wireless ETH.
Then I loaded the Raspberry Pi with a fairly new CODESYS runtime (3.5.14.0) + reboot.
When I insert the dongle and start the License Manager (Tools->License manager) and select the runtime, the dongle is not discovered and "System Info"
shows me the message "no runtime license - running in demo mode(~119 minutes)" :cry:
It seems USB is not working properly, which is weird because if I plug in the dongle some lights are starting to flash on/off.
ps $dmesg shows the wibu dongle,
$lsusb also shows the dongle.
=> What am I doing wrong?
CfUnit, free and open-source IEC61131-3 unit-testing framework
My profile
PostPosted: Tue Aug 06, 2019 8:05 am
I would sugguest the following:
check with:
lsusb -v
if your runtimekey device is a ' HID' -3 Human Interface Devic konfigured device:
This should look like this:
lsusb -v
Bus 001 Device 004: ID 064f:2af9 WIBU-Systems AG CmStick (HID, article no. 1001-xx-xxx)
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x064f WIBU-Systems AG
idProduct 0x2af9 CmStick (HID, article no. 1001-xx-xxx)
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0022
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 3 Human Interface Device
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
If so, it should work without any modification.
If it s a storage device - then you need to mount the key or change it to HID device ( prefered to change it to HID device - http://localhost:22352/$help/CmUserHelp ... to_hid.htm)
If this does not work this way... it is an error.
Last edited by Edwin Schwellinger on Tue Aug 06, 2019 7:59 pm, edited 1 time in total.
PostPosted: Tue Aug 06, 2019 8:28 am
The output of $ lsusb -v; contains several lines of text among which;
bInterfaceSubClass 6 SCSI
It shows a SCSI device (no HID), so on to step 2..:
* Stick into CODESYS devbox where Codemeter Control Center Runs,
* Update the Dongle formware to most recent version (if necesary),
* Open the webadmin interface and the help and search for HID,
* Follow the instructions on making the dongle a USB-HID carefully (see the help itself for exact instructions)
  Communication mode changed successfully.
  Please replug your CmDongle to apply the changes.
* USB stick into RPi + reboot
* Check license via CODESYS IDE license manager
Succes!
Thank you!
My profile
PostPosted: Tue Feb 04, 2020 12:58 pm
I have a USB dongle with a license for Raspberry Pi that I bought in 2015 but is not working anymore.
When I do "lsusb -v" My USB dongle shows up as a storage device. What do I need to do to change it to HID?
This link is not working: http://localhost:22352/$help/CmUserHelp ... to_hid.htm
Thank you.
PostPosted: Tue Feb 04, 2020 1:43 pm
http://localhost:22352/$help/CmUserHelp ... center.htm
cmu32 /s [Boxenmaske-Seriennummer] --set-config-disk HidCommunication
PostPosted: Wed Feb 05, 2020 3:04 pm
Thanks. It worked.
I had not realized that the link was pointing to localhost. I was trying to open the link on a PC where Code Meter was not installed.
Thank you
PostPosted: Wed Feb 05, 2020 7:00 pm
Can we use any Codemeter CmStick from Wibu?
The CmStick/C Basic for installed devices and the CmStick ME for developing seemed like interesting options.
