It is currently Thu Aug 22, 2019 4:41 pm
PostPosted: Tue Jul 30, 2019 4:06 pm
Is there a FB (OSCAT maybe?) I can use to read the content of a web page (https)?.
I need to extract some value from a website
Thanks
Flea
PostPosted: Tue Jul 30, 2019 5:59 pm
check this example:
https://store.codesys.com/http-client-example.html
Make CODESYS great again
PostPosted: Wed Jul 31, 2019 8:56 am
thanks for suggestion, I've tried with the sample from 3s but it cannot make it work..all the times I get error.. Does anyone use it recently? (ps. I've tested with http and https both)
PostPosted: Wed Jul 31, 2019 3:09 pm
How you tested it, maybe in simulation? It does not work this way, you should use real PLC or CODESYS Control Win V3 (soft-plc).
PostPosted: Fri Aug 02, 2019 10:07 am
I've tested using Control Win3. I get TCP read error every time
PostPosted: Fri Aug 02, 2019 10:30 am
For me it works without problems...
You need to check your network settings, maybe you have problem with routing of packets.
PostPosted: Thu Aug 08, 2019 10:29 am
Hi Kislov,
you're right, it was an issue on my connection, Now I can get the done from FB. Just one question: I've like to get in string format the content of web page but I get only this:
I've expected something like this (as if I get the "save as" page from web browser) it isn't?
<!DOCTYPE html>
<html lang="de"><head>
<title>Online-measurement of the mains frequency</title>
<meta charset="utf-8">
<meta http-equiv="content-type" content="text/html; charset=UTF-8">
<meta name="description" content="Measurement of the utility frequency (line/grid frequency) of the european grid">
<meta name="author" content="Thomas Gobmaier">
<meta name="keywords" content="line frequency, grid frequency, mains frequency, power frequency, 50 Hz, 50Hz, UCTE, ENTSO, ENTSO-E, PRIMARY CONTROL">
<link rel="apple-touch-icon" sizes="76x76" href="https://www.mainsfrequency.com/apple-touch-icon.png">
<link rel="icon" type="image/png" sizes="32x32" href="https://www.mainsfrequency.com/favicon-32x32.png">
<link rel="icon" type="image/png" sizes="16x16" href="https://www.mainsfrequency.com/favicon-16x16.png">
<link rel="manifest" href="https://www.mainsfrequency.com/site.webmanifest">
<link rel="mask-icon" href="https://www.mainsfrequency.com/safari-pinned-tab.svg" color="#5bbad5">
<meta name="msapplication-TileColor" content="#da532c">
<meta name="theme-color" content="#ffffff">
<link href="Online-measurement%20of%20the%20mains%20frequency_files/webstyle_3.css" rel="stylesheet" type="text/css" media="screen">
<!--[if IE]><script type="text/javascript" src="./excanvas.min.js"></script><![endif]-->
<script type="text/javascript" async="" src="Online-measurement%20of%20the%20mains%20frequency_files/ga.js"></script><script language="JavaScript" type="text/javascript">
    var req=0;
    var url0 = "https://netzfrequenzmessung.de:9080/frequenz01.xml";
   var pfeil_pos=1;
    var frequenz = 0.0;
    var frequenzAlt= 50.2;
    var frequenzDelta= 0.0;
    var frequenzPos= 50.2;
   var masse=5.0;
   var feder=75;
   var daempfung=3.0;
   var beschl=0;
   var geschwindigkeit=0;
   var frequenzLinPol=50.2;
   var phasenwinkel = 0.0;
   var phasenwinkelAlt = 0.0;
   var phasenwinkelDelta = 0.0;
   var RL=0.0;
   var RLAlt= 0.0;
    var RLDelta= 0.0;
    var RLPos= 0.0;
   var pfeil_RL=1;
   var gf, gm, gms;
   var ergebnis ="ab";
   var sperr=false;
   var Winkel = -0.001;
   var phasenwinkeltext = "  0";
   var size=20;
