It is currently Tue Feb 18, 2020 2:20 am
PostPosted: Fri Jul 12, 2019 9:05 am
Hello everyone,
My aim is to establish CAN bus network using Raspberry Pi + MCP2515, programmed in CodeSYS.
On the hardware's side, I have connected the SPI pins of MCP2515 to the corresponding SPI pins of Raspberry Pi. As for the INT pin, I have connected it to GPIO25 (this comes after many posts mentioned the use of pin 25 for INT).
The GND and VCC for MCP2515 are connected to GND and 3.3V pin on Raspberry Pi.
I have seperately soldered a 5V connection to TJA1050 by etching out the bridging capacitor.
On the Linux side, I downloaded CAN utils, enabled corresponding overlays, and got the CANbus to working. It is fully functional.
I monitor the messages using PCAN USB Pro.
Now, the real problem is with CodeSYS library.
Everytime I attempt to configure the driver, the CL2 library either throws an "INTERNAL ERROR" or a "NO DRIVER" error!
I loaded every possible CMPManager file, every CodeSYSConfig file on Linux. However, the problem still persists.
I just don't understand what the real problem is.
Can somebody throw some light??
I will be greatly indebted.
PostPosted: Fri Jul 12, 2019 10:12 am
Now, the Runtime info on CodeSYS says that a command can't be executed.
Can somebody tell me what's going on?
PostPosted: Sun Jul 14, 2019 6:23 am
did you add in /etc/CODESYSControl_User.cfg
[CmpSocketCanDrv]
ScriptPath=/opt/codesys/scripts/
ScriptName=rts_set_baud.sh
the sript is:
#!/bin/sh
BITRATE=`expr $2 \\* 1000`
ifconfig $1 down
echo ip link set $1 type can bitrate $BITRATE
ifconfig $1 up
should be in /opt/codesys/scripts/rts_set_baud.sh
and need to be executable.
sudo chmod +x /opt/codesys/scripts/rts_set_baud.sh
PostPosted: Thu Jul 18, 2019 2:27 pm
Edwin,
I added everything you mentioned.
And, my Can bus works!
Thanks so much!!!
