It is currently Sat Jan 18, 2020 11:50 pm
 Post subject: PI4 with CODESYS
PostPosted: Wed Jun 26, 2019 7:13 am
if anyone has this new PI4 device in his hands,
feedback on using it with the CODESYS runtime would be much appreciated!
Thanks
 Post subject: Re: PI4 with CODESYS
PostPosted: Fri Jun 28, 2019 9:42 am
Hello Edwin,
we have already tested the PI 4 with CODESYS SP14 and run into problems.
Configuration:
Runtime SP14
Fresh Raspbian Buster (updated this morning on the latest version)
RPi 4 with 1 GB RAM
After the installation of the runtime via the CODESYS IDE, the runtime starts and is running for a short time. After a few seconds the codesys task is gone. Same thing after a reboot of the system.
Some logs for you:
;<loggername>/tmp/codesyscontrol.log</loggername>
;<logoptions>
;   <enable>1</enable>
;   <type>normal</type>
;   <timestamp>rtc</timestamp>
;   <deactivatable>0</deactivatable>
;   <dump>always</dump>
;   <filter>0x0000000f<filter>
;   <maxentries>1000</maxentries>
;   <maxfiles>1</maxfiles>
;   <maxfilesize>1000000</maxfilesize>
;</logoptions>
;<entries>
;Timestamp, CmpId, ClassId, ErrorId, InfoId, InfoText
;</entries>
1561709038, 0x00000013, 1, 0, 0, <logoptions>
1561709038, 0x00000013, 1, 0, 0, <bEnable>1</bEnable>
1561709038, 0x00000013, 1, 0, 0, <type>normal</type>
1561709038, 0x00000013, 1, 0, 0, <timestamp>rtc</timestamp>
1561709038, 0x00000013, 1, 0, 0, <disableable>0</disableable>
1561709038, 0x00000013, 1, 0, 0, <Filter>0x0000000f<Filter>
1561709038, 0x00000013, 1, 0, 0, <MaxEntries>1000</MaxEntries>
1561709038, 0x00000013, 1, 0, 0, <MaxFiles>1</MaxFiles>
1561709038, 0x00000013, 1, 0, 0, <MaxFileSize>1000000</MaxFileSize>
1561709038, 0x00000013, 1, 0, 0, </logoptions>
1561709038, 0x00000001, 1, 0, 4, CODESYS Control V3
1561709038, 0x00000001, 1, 0, 5, Copyright (c) 3S - Smart Software Solutions GmbH
1561709038, 0x00000001, 1, 0, 6, <version>3.5.14.0</version> <builddate>Dec 11 2018</builddate>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>CM</cmp>, <id>0x00000001</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>CmpMemPool</cmp>, <id>0x0000001e</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>CmpLog</cmp>, <id>0x00000013</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>CmpSettings</cmp>, <id>0x0000001a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysFile</cmp>, <id>0x00000104</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysTimer</cmp>, <id>0x00000116</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysTimeRtc</cmp>, <id>0x00000127</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysTime</cmp>, <id>0x00000115</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysTask</cmp>, <id>0x00000114</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysTarget</cmp>, <id>0x00000112</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysSocket</cmp>, <id>0x00000111</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysShm</cmp>, <id>0x00000110</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysSemProcess</cmp>, <id>0x00000119</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysSemCount</cmp>, <id>0x00000139</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysSem</cmp>, <id>0x0000010f</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysProcess</cmp>, <id>0x0000010e</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysOut</cmp>, <id>0x0000010b</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysMutex</cmp>, <id>0x0000013a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysMsgQ</cmp>, <id>0x0000010a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysModule</cmp>, <id>0x00000109</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysMem</cmp>, <id>0x00000108</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysInternalLib</cmp>, <id>0x00000107</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>_</cmp>, <id>0x00000103</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysEvent</cmp>, <id>0x00000102</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysEthernet</cmp>, <id>0x0000011c</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysDir</cmp>, <id>0x0000011b</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysCpuHandling</cmp>, <id>0x00000101</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, System: <cmp>SysCom</cmp>, <id>0x00000100</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpWebServerHandlerV3</cmp>, <id>0x00000072</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpWebServer</cmp>, <id>0x00000071</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpVisuServer</cmp>, <id>0x00000057</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpVisuHandler</cmp>, <id>0x00000054</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpUserMgr</cmp>, <id>0x00000061</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpUserDBObjects</cmp>, <id>0x00000091</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpUserDB</cmp>, <id>0x00000064</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpTraceMgr</cmp>, <id>0x00000070</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpSrv</cmp>, <id>0x0000001c</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpSocketCanDrv</cmp>, <id>0x00005f0d</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpSecurityManager</cmp>, <id>0x0000008e</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpSecureChannel</cmp>, <id>0x00000090</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpSchedule</cmp>, <id>0x00000019</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpRouter</cmp>, <id>0x00000018</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpRetain</cmp>, <id>0x00000017</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpRasPi</cmp>, <id>0x00000089</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpPlcShell</cmp>, <id>0x00000128</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpOpenSSL</cmp>, <id>0x00000033</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpOPCUAStack</cmp>, <id>0x0000008d</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpOPCUAServer</cmp>, <id>0x00000124</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpOPCUAProviderIecVarAccess</cmp>, <id>0x00000126</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpNameServiceServer</cmp>, <id>0x00000016</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpNameServiceClientIec</cmp>, <id>0x0000011d</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpNameServiceClient</cmp>, <id>0x00000015</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpMonitor2</cmp>, <id>0x00000032</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpKnxStack</cmp>, <id>0x0000004d</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpIoMgr</cmp>, <id>0x00000012</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpIoDrvIec</cmp>, <id>0x0000005a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpIecVarAccess</cmp>, <id>0x00000060</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpIecTask</cmp>, <id>0x00000011</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpIecStringUtils</cmp>, <id>0x0000007f</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpGwCommDrvTcp</cmp>, <id>0x00000010</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpGateway</cmp>, <id>0x0000000f</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpFileTransfer</cmp>, <id>0x0000005e</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpEventMgr</cmp>, <id>0x0000005b</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpEL6751CanDrv</cmp>, <id>0x00005f0b</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpDynamicText</cmp>, <id>0x00000051</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpDevice</cmp>, <id>0x0000000e</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCryptMD5</cmp>, <id>0x0000006a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCoreDump</cmp>, <id>0x00000083</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCommunicationLib</cmp>, <id>0x0000000c</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCodeMeter</cmp>, <id>0x0000007a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpChecksum</cmp>, <id>0x0000000b</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCharDevice</cmp>, <id>0x00000300</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpChannelServer</cmp>, <id>0x0000000a</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpChannelMgr</cmp>, <id>0x00000009</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpChannelClientIec</cmp>, <id>0x0000005d</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpChannelClient</cmp>, <id>0x00000008</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAATypes</cmp>, <id>0x00004006</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAATimer</cmp>, <id>0x00004016</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAATickUtil</cmp>, <id>0x00004010</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAATick</cmp>, <id>0x00004009</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAAStorage</cmp>, <id>0x0000007e</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAASerialCom</cmp>, <id>0x00004012</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAASegBufferMan</cmp>, <id>0x00004019</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAASdoServer</cmp>, <id>0x00004017</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAASdoClient</cmp>, <id>0x00004011</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAARealTimeClock</cmp>, <id>0x00004014</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAANetBaseServices</cmp>, <id>0x00004018</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAAMemBlockMan</cmp>, <id>0x00004003</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAAFile</cmp>, <id>0x00004008</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAADTUtil</cmp>, <id>0x00004013</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAACanL2</cmp>, <id>0x00004004</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAACallback</cmp>, <id>0x00004001</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAABehaviourModel</cmp>, <id>0x00004015</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpCAAAsyncMan</cmp>, <id>0x00004007</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpBlkDrvUdp</cmp>, <id>0x00000007</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpBlkDrvTcp</cmp>, <id>0x00000030</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpBitmapPool</cmp>, <id>0x00000050</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpBinTagUtilIec</cmp>, <id>0x0000005c</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpBinTagUtil</cmp>, <id>0x00000004</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpBACnet</cmp>, <id>0x00000400</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpAsyncMgr</cmp>, <id>0x0000005f</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpAppForce</cmp>, <id>0x00000074</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpAppBP</cmp>, <id>0x00000073</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpApp</cmp>, <id>0x00000002</id> <ver>3.5.14.0</ver>
1561709038, 0x00000001, 1, 0, 10, <cmp>CmpAlarmManager</cmp>, <id>0x0000007c</id> <ver>3.5.14.0</ver>
1561709038, 0x0000000a, 1, 0, 0, <NumOfChannels>4</NumOfChannels> channels available, each of the size <BufferSize>100000</BufferSize> Bytes
1561709038, 0x00000009, 1, 0, 2, Running as network server
1561709038, 0x00000009, 1, 0, 1, Running as network client
1561709038, 0x00000007, 1, 0, 6, Network interface: <ipaddress>127.0.0.1</ipaddress>, subnetmask <subnetmask>255.255.255.0</subnetmask>
1561709038, 0x00000018, 1, 0, 4, Network interface <interface>ether local</interface> at router <instance>0</instance> registered
1561709038, 0x00005f0d, 1, 0, 1, interface <interface>can0</interface> is not available
1561709038, 0x00000124, 1, 0, 0, No certificate for the OPC UA server available.
1561709038, 0x00000124, 1, 0, 0, Security policy allows plain text communication. Secure communication is deactivated.
1561709038, 0x00000124, 1, 0, 0, **************************************************************
1561709038, 0x00000124, 1, 0, 0,     OPC UA Server Started:
1561709038, 0x00000124, 1, 0, 0,     Hostname: raspberrypi, Port: 4840
1561709038, 0x00000124, 1, 0, 0,     URL: opc.tcp://raspberrypi:4840
1561709038, 0x00000124, 1, 0, 0,     Loopbackadapter activated.
1561709038, 0x00000124, 1, 0, 0,     All available networkadapters are used.
1561709038, 0x00000124, 1, 0, 0, Provider CODESYS_DefaultProvider with Version 0x3050e00 registerd at the OPC UA server.
1561709038, 0x00000124, 1, 0, 0, Provider CmpOPCUAProviderIecVarAccess with Version 0x3050e00 registerd at the OPC UA server.
1561709038, 0x00000030, 1, 0, 6, Local network address: <ipaddress>127.0.0.1</ipaddress>
1561709038, 0x00000018, 1, 0, 4, Network interface <interface>BlkDrvTcp</interface> at router <instance>1</instance> registered
1561709038, 0x00000018, 1, 0, 1, Setting router <instance>0</instance> address to <address>(0001)</address>
1561709038, 0x00000018, 1, 0, 1, Setting router <instance>1</instance> address to <address>(2ddc:7f00:0001)</address>
1561709045, 0x00000126, 1, 0, 0, Valid license found for OPC UA IecVarAccess provider.
1561709045, 0x00000002, 1, 0, 22, No retain area in bootproject of application [<app>Application</app>]
1561709045, 0x00000002, 1, 0, 6, Bootproject of application [<app>Application</app>] loaded
1561709045, 0x00000002, 1, 0, 10, Application [<app>Application</app>] started
1561709045, 0x00000001, 1, 0, 34, CODESYS Control ready
1561709045, 0x0000100c, 1, 0, 0, Visuinitialization starting.
1561709047, 0x00001000, 4, 0, 0, TrendStorageAccess: Some kind of disk I/O error occurred. Check disk space.
1561709047, 0x00001000, 4, 0, 0, TrendStorageAccess: No more write access to the trend storage will be performed.
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/visuelemsdatetime.tl_datetime.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/visuelemsalarm.tl_alarmtablecolumntitles.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/visuelemsalarm.alarmmanager.tl_alarmstatus.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/visuelem3dpath.globaltextlist.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/visudialogs.globaltextlist.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/tltrend.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/tlpwmmodeselection.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/tlprescaler8bit.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/tlprescaler16bit.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/system.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_smc_ptp_movement_type.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_smc_orientation_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_smc_coord_system.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_smc_circ_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_mc_transition_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_mc_execution_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_mc_circ_pathchoice.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.textlistforcombobox_mc_buffer_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_robotics_visu.globaltextlist.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_toolcorrmode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_smoothpathmode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_smoothpathaddaxmode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_smoothbspline_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_ori_convention.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_int_velmode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_int_status.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_abc_slopes_no_stop.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_smc_abc_slopes_at_stop.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.textlistforcombobox_mc_direction.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_cnc.globaltextlist.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_ramptype.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_movementtype.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_loggermode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_homing_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_controller_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_backlash_startstate.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc_backlash_mode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_smc3_brakesetstate.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_mc_tappetmode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_mc_startmode.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.textlistforcombobox_mc_direction.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/sm3_basic.globaltextlist.txt</file> could not be opened
1561709047, 0x00000051, 4, 0, 1, The dynamic text file <file>$visu$/globaltextlist.txt</file> could not be opened
1561709047, 0x0000100c, 1, 0, 0, Visuinitialization done.
1561709047, 0x0000007e, 4, 16, 0, Opening file 'PlcLogic/' with flags 102 failed!
1561709047, 0x00001000, 4, 0, 0, TrendStorageAccess: Determination of root pages for recording did not work, error code: 30440
1561709047, 0x00000071, 1, 0, 0, **************************************************************
1561709047, 0x00000071, 1, 0, 0,          Web Server
1561709047, 0x00000071, 1, 0, 0,       Root directory : $PlcLogic$/$visu$
1561709047, 0x00000071, 1, 0, 0,       Host :       raspberrypi
1561709047, 0x00000071, 1, 0, 0,       HTTP port  : 8080
1561709047, 0x00000071, 1, 0, 0,       HTTPS port : 443
1561709047, 0x00000071, 1, 0, 0,       Connection type : HTTP
1561709050, 0x00000018, 1, 0, 5, Network interface <interface>ether local</interface> unregistered
1561709050, 0x00000007, 1, 0, 6, Network interface: <ipaddress>192.168.1.166</ipaddress>, subnetmask <subnetmask>255.255.255.0</subnetmask>
1561709050, 0x00000018, 1, 0, 4, Network interface <interface>ether 1</interface> at router <instance>2</instance> registered
1561709050, 0x00000018, 1, 0, 1, Setting router <instance>2</instance> address to <address>(00a6)</address>
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
| Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
         Halb installiert/Trigger erWartet/Trigger anhängig
|/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
||/ Name           Version      Architektur  Beschreibung
ii  codesyscontrol 3.5.14.0     all          V3.5.14.0, Di 11. Dez 16:11:42 CET 2018
processor   : 0
model name   : ARMv7 Processor rev 3 (v7l)
BogoMIPS   : 270.00
Features   : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer   : 0x41
CPU architecture: 7
CPU variant   : 0x0
CPU part   : 0xd08
CPU revision   : 3
processor   : 1
BogoMIPS   : 270.00
CPU architecture: 7
CPU variant   : 0x0
CPU part   : 0xd08
CPU revision   : 3
processor   : 2
BogoMIPS   : 270.00
CPU architecture: 7
CPU variant   : 0x0
CPU part   : 0xd08
CPU revision   : 3
processor   : 3
BogoMIPS   : 270.00
CPU architecture: 7
CPU variant   : 0x0
CPU part   : 0xd08
CPU revision   : 3
Hardware   : BCM2835
Revision   : a03111
Serial      : 100000003691d0b5
It would be great if you can send us information how to get it running. We want to use Pi 4 and CODESYS with out PiXtend PLC devices as soon as possible.
Kind regards!
PostPosted: Fri Jun 28, 2019 12:59 pm
we will implement these changes and release them with the 3.5SP15 release on July.
Thanks for the information.
PostPosted: Thu Jul 18, 2019 2:41 am
The latest CODESYS build (3.5.14.30) as of this post does not recognize the new Raspberry Pi 4 Build B when scanning the local subnet. It has a new OUI and the prefix is DC:A6:32.
I can confirm that with the Buster build (Version:July 2019, Release date:2019-07-10), the runtime briefly executes, then terminates.
PostPosted: Sat Sep 14, 2019 10:07 am
any news about the PI4 with codesys
PostPosted: Sat Sep 14, 2019 2:57 pm
With 3.5.15.10 release date is 19th this month - these buster problems will be solved.
