It is currently Wed Feb 26, 2020 7:00 pm
PostPosted: Mon Jun 24, 2019 8:10 pm
Hello.
Does anyone have any examples how to use devices from this library?
Especially how to use 24C512?
PostPosted: Sat Jun 29, 2019 8:45 am
Hi Pawel,
sure I know this… :D
The eeprom works assyncron call it like this:
   IF SysSem.SysSemEnter(hSem:=PARAM_DATA.DATA_EEPROM.SEMAPHORE) = SysSem.Errors.ERR_OK THEN
      IF PARAM_DATA.DATA_EEPROM.FB_NO_IN = 0 THEN
         PARAM_DATA.DATA_EEPROM.FB_NO_IN := PARAMETER_NO;
         PARAM_DATA.DATA_EEPROM.WRITE_VALUE := TRUE;
         PARAM_DATA.DATA_EEPROM.VALUE_IN.LWORD_T := PARAM.LWORD_T;
         PARAM_DATA.DATA_EEPROM.ADDRESS_VALUE := GET_PAGE_ADRESS_EEPROM(DATA:= PARAM_DATA);
   SysSem.SysSemLeave(hSem:=PARAM_DATA.DATA_EEPROM.SEMAPHORE);
try to use the device as no multiplex in device config.
shows that the EEPROM is read to recive new command.
FB_NO_IN can be any UNIQUE number on your PLC this number shows the write or reciving FB that data for this FB is avalible. I create thos Nums by call
Quote:
DB_IN_OUT^.FB_NO_AUTO := DB_IN_OUT^.FB_NO_AUTO + 1;
in each FB
and reset them in on FB like:
DB_IN_OUT.FB_NO_AUTO := 0;//reset FB number
IF DATA_EEPROM.FB_NO_OUT = PARAMETER_NO THEN
   //got my request back
shows that data from eeprom is avalible.
then you can receive the data like this:
   //get value
   VALUE_FROM_EEPROM.LWORD_T := DATA_EEPROM.VALUE_OUT.LWORD_T;
   DATA_EEPROM.FB_NO_OUT := 0;//delete response
   LOAD_VALUE_FROM_EEPROM := FALSE;//delete request
I think I have to make a god example too.
BR Stefan
