It is currently Tue Oct 22, 2019 12:37 pm
Post new topic  Reply to topic  [ 28 posts ]  Go to page 1 2 Next
 Post subject: Ethernet/Ip Slave
PostPosted: Wed Aug 06, 2014 11:08 pm
Are there any way to turn my Raspberry Pi into an Ethernet/Ip adapter (Slave) in order to Read/Write Codesys arrays from an Allen Bradley ControlLogix PLC?
I'm trying to find an easy way to make my Raspberry Pi communicate with a ControlLogix PLC through Ethernet. Any suggestions?
Thank you.
 Post subject: Re: Ethernet/Ip Slave
PostPosted: Thu Aug 07, 2014 5:12 am
this is an open point on the roadmap I see the following improvement in our database:
CDS-31944 EtherNet/IP: Implement EtherNet/IP Adapter
Is it possible to realize it vice versa Raspberry Pi = EtherNet/IP Scanner , Rockwell = EtherNet/IP Adpater?
found this tutorial which demonstrates how to setup Ethernet/IP scanner(sure with another adapter): https://www.youtube.com/watch?v=QrV7laAJkDk
PostPosted: Thu Nov 06, 2014 1:29 pm
Thanks for your reply but I don't think it is possible to use a ControlLogix as an Ethernet/IP adapter.
Would it be possible to use Produced/Consumed tags over Ethernet/IP between CODESYS and a ControlLogix?
PostPosted: Fri Jan 23, 2015 9:07 pm
No, it's not possible. I think this feature ist availabel in version 3.5Sp7.
The EtherNet/IP adapter in the actual version have not a functionality.
This is the answer from the official codesys support:
wir haben bisher nur den Scanner als eigenen Stack,
der Adapter wird vermutlich zu 3.5Sp7 folgen,
das heitß Sie können das aktuelle noch nicht mit dem PI Machen
Der grund warum man den in CODESYS dazumachen kann ist weil er als BASIS für eine Hilscher Cifx Karte mal konfiguriert wurde..
Bin mir aber nicht sicher ob das aktuell noch geht.
Ich hoffe das wird aus dem CODESYS Setup entfernt werden und erst wieder reingemacht wenn unser eigener Slave Stack
Fertig ist.
PostPosted: Sat Jan 24, 2015 8:41 pm
Thanks a lot for your reply.
I'll be watching for 3.5 SP7.
Thank you.
PostPosted: Fri Aug 28, 2015 10:37 pm
With the new Version V3.5 SP7 Patch 1 it works.
The EtherNet_IP_Adapter must be version 3.5.7.10.
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Instructions in the appendix!
PostPosted: Mon Sep 07, 2015 1:14 am
I am very new to CodeSys so if this is an obvious answer please bear with me.
I was able to create a very simple project and add the EthernetIP modules for inputs & outputs.
I Configured an AB L32E Compactlogix processor for generic ethernet io and that appears to be functional as well. The IO tree indicates no problems. If I unplug the ethernet cable from the RPi the IO tree indicates an issue. If I manually edit the input value it gets reset to zero. So I am pretty sure the L32E is talking to the RPi OK.
My goal was to have a single line ladder program that moved the Ethernet Input word to the Ethernet Output word. Thus if I change the output word in the L32E it should show up in the input word in the L32E. However I have been unable to accomplish this. I can not even get the Ethernet Input word to show any indication that it is receiving data from the L32E.
Any help would be greatly appreciated.
PostPosted: Mon Sep 07, 2015 1:57 am
Progress!!! But new questions. :)
I believe I ran into my 2 hr limit and after that the Ethernet devices had a red triangle next to them. I could not figure out how to start the bus again so I deleted the ethernet/ip devices and re-entered them. My simple program with a single rung (mov) instruction now works. Not sure what the heck was wrong to begin with.
First new question, how do I get the red triangles to disappear without deleting & re-entering the Ethernet/IP devices?
2nd Question, is there any way to have more than one input and one output word for the Ethernet/IO slave?
PostPosted: Tue Sep 22, 2015 5:13 pm
I also want to know how to add more IOs in the EthernetIp Module.
It must be possible to exchange an array of bytes for exemple?
Thank you.
PostPosted: Tue Sep 22, 2015 6:50 pm
that way.. and let me check if array's and more is possible.
PostPosted: Sun Dec 06, 2015 11:48 pm
Hi everyone,
Sure it's possible to use Raspi as an node with CompactLogix AB, but not sure if it's possible to read and write data, actualy, with my setup, i can read data from Raspi with my compactlogix, but in the other direction (Write Data from CompactLogix to Raspi), look's bad for the moment!
At the Codesys Side (Raspi), i create 1 ENIP module (For Input transaction) and 1 ENIP module (For Output transaction) only Output working!
From Compactlogix, to read data from raspi node, i use Service Code 0X0EH an it run and to tried to write data to Raspi, i used Service Code 0X10H but i receive this message (Unsupported service requested)!!!! :evil:
If somebody did, could you help me?
Regards
Eric Dostie
iko innovations
PostPosted: Mon Feb 01, 2016 1:42 am
This looks very exciting. I can get the Pi online with no errors, but seems not able to read it from the Controllogix. Which CIP message should I use?
I appreciate the help so much!
PostPosted: Mon Feb 01, 2016 6:07 am
I would recommend to use the attached EDS file.
This is the EDS which is installed in the CODESYS device repository
PostPosted: Mon Feb 01, 2016 5:10 pm
Thank you for the reply Edwin!
I tried to install the EDS file with RSLinx on the controllogix, however I still cannot get the Controllogix talk to the Pi...
I attached some screenshots which indicates the communication loss.
Any helps are highly appreciated!
PostPosted: Mon Feb 01, 2016 7:11 pm
if you are online is the EIP Adapter 'green'?
You could add the device name of the adapter (name in the device tree) to the watchlist to have more diagnosis Information.
