It is currently Thu Feb 27, 2020 11:34 pm
PostPosted: Wed Jun 05, 2019 9:04 am
Currently have an Allen Bradley 1734-AENT (CIP Ethernet) Module, with 4 points of IO. In the first slot is two 1734-IB4 (4 point Input), and in the second slot is two 1734-OB8 (8 Point Output). The point IO is configured . I have downloaded Codesys to run on my Raspberry Pi 3 b+. The code runs on my PI, I have just a simple program the input aren't update
the outputs haven't problem since I can force each of them without problem.
Anybody else bumped into this problem yet and able to help?
I'm using the newest releases of Codesyscontrol and Codesys Development system.
PostPosted: Thu Jun 06, 2019 4:53 pm
the inputs are not updated, because you don't use it in any program. To update without any usage, you have to change the update mode in the EtherNet/IP I/O Mapping section to: Enabled 2 (always in bus cycle task) f.eg.:
PostPosted: Fri Jun 07, 2019 4:41 pm
thanks D. Kugler for your answer.
I have modified the file, changing the update mode in the EtherNet / IP I / O Mapping section to: Enabled 2 (always in bus cycle task).
the entries, at first take a correct value, but then they are not updated.
I add the new file.
Any more idea than it could be?
