It is currently Tue Feb 18, 2020 3:03 am
Post new topic  Reply to topic  [ 10 posts ]
PostPosted: Mon Apr 29, 2019 4:21 pm
Hi, i'm trying to show a codesys page with webvisu on a browser page, i have a visualization problem with the measurement controls, the meter180 and meter 360. I tryed with different browser but i had the same problem.
In the codesys wiew i have no errors, but in the browser one i have.
I attached 3 images wich show the results.
I'm using codesys v3.5 sp14 patch 2 + (64bit) and a raspberry v3.5.14.20
How can i solve the problem?
PostPosted: Mon Apr 29, 2019 5:19 pm
could you check the plc logger?
PostPosted: Mon Apr 29, 2019 5:33 pm
hi Edwin,
here is the log xml.
thanks
PostPosted: Mon Apr 29, 2019 7:53 pm
could you browse by CODESYS file browser if these svg's and other grafic images are downloaded to the pi?
Seems not.
Additional check this setting 'preview Support client animations and overlay...'
Either
PostPosted: Tue Apr 30, 2019 9:22 am
Hi Edwin, first of all thanks for the help.
I downloaded again the raspberry runtime but the problem was still there.
A couple hours after the issue seemed solved by itself, i don't know how. However i did what you told me to do. The svg files are now in the right place.
Best regards
PostPosted: Thu Aug 22, 2019 2:17 pm
it seems that this Problem is still existing.
My case is nearly the same.
When i use the webvisualisation the .svg are shown with an red X.
These .svg are coming from the codesys symbols library.
But also a imported .svg logo is not shown, in this case without the red X.
The log shows the same problem.
First it was working fine all .svg s have been shown. But then i had this problem.
I have this since more than 1 month with many transfers. In my case no self solution.
The .svg s are not in the PlcLogic/visu directory. And a transfer don't copy them.
The logo .svg is in this directory but is also not shown.
I'm using Codesys 3.5.14 Patch 1 on an raspberry pi 3. The used Browser is Chrome, Firefox.
Whit internet explorer i have other problems
Do somebody know what to do?
I tried already the given solutions in this thread....
PostPosted: Fri Aug 23, 2019 6:54 am
I had this once, not sure if it helps:
Delete the Visumanager and then add it again... add Webvisu and Startvisu in it.
Maybe this will solve it.
PostPosted: Fri Aug 23, 2019 7:24 am
Hi Edwin,
thanks. I tried it but the problem stays the same. :cry:
Some Other Ideas? :?:
PostPosted: Fri Aug 23, 2019 7:44 pm
Does an empty new project work without problems?
Sure an update to newest version.. is an option too.
BR Edwin
PostPosted: Thu Sep 26, 2019 9:32 am
Problem solved,
the symbol .svg haven't been transfered to the PLC because they have only been integrated as an instance by their name.
I now created an Symbol page whit all used symbols, now they will be transfered to the PLC.
The Logo .svg was not a real .svg, only an .svg implementing a .bmp and was therefor not scalled correctly.
Thanks for your help.
