Fehler
Die Lizenz kann nicht in den gewählten Lizenzcontainer übertragen werden. Bitte wählen Sie einen anderen Lizenzcontainer und versuchen Sie es erneut.
0x18080003
CodeMeter License Central WebDepot v16.03.165.500.ws
2019-03-20 15:19:55 (UTC)
If I insert the dongle
lsusb output:
WIBU-Systems AG CmStick (article no. 1001)
dmesg output
110.771870] usb 1-1.2: USB disconnect, device number 5
[ 435.930925] usb 1-1.2: new full-speed USB device number 7 using dwc_otg
[ 436.065517] usb 1-1.2: New USB device found, idVendor=064f, idProduct=03e9
[ 436.065547] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 436.065559] usb 1-1.2: Product: CodeMeter-Stick
[ 436.065569] usb 1-1.2: Manufacturer: WIBU-SYSTEMS AG
[ 436.065578] usb 1-1.2: SerialNumber: 000003032873
[ 436.069996] usb-storage 1-1.2:1.0: USB Mass Storage device detected
[ 436.089596] scsi host0: usb-storage 1-1.2:1.0
[ 437.102927] scsi 0:0:0:0: Direct-Access WIBU - CodeMeter-Stick v1.0 PQ: 0 ANSI: 2
[ 437.107837] sd 0:0:0:0: [sda] 80384 512-byte logical blocks: (41.2 MB/39.3 MiB)
[ 437.109868] sd 0:0:0:0: [sda] Write Protect is off
[ 437.109899] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 437.114806] sd 0:0:0:0: [sda] No Caching mode page found
[ 437.114837] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 437.127140] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 437.143088] sda: sda1
[ 437.152632] sd 0:0:0:0: [sda] Attached SCSI disk
[ 6206.351312] R8188EU: sta recv deauth reason code(2) sta:80:ea:96:f2:35:72
[ 6206.373194] R8188EU: indicate disassoc
[ 6209.333550] R8188EU: assoc success
I can’t install a license on them, then on the license manager say, no container found?
What could I do?
I would plug the key to the CODESYS PC - and use the browser to activate the license on the key. ( to workaround this)
https://license.codesys.com
Thanks for the answer
i have checked it today but it doesnt work.
Fehler
0x18080003
would recommend to contact our CODESYS store helpdesk -> my question -> bugreport
add your license ticketnumber to the request
