https://forum.codesys.com/
Can't connect
https://forum.codesys.com/viewtopic.php?f=21&t=9480
Page 1 of 1
Author:  urbanlarsson [ Mon Jan 28, 2019 9:20 am ]
Post subject:  Can't connect
Hi!
I have reconnected my old Raspberry with Codesys, updated Codesys to 3.4.15 and also updated the Pi to 3.5.14.
But now i can't connect, Codesys won't see my Pi, please advice.
I can read system info and start/stop but not login and scan network doesn├Ąt find anything.
/U
Author:  Edwin Schwellinger [ Mon Jan 28, 2019 11:18 am ]
Post subject:  Re: Can't connect
add the Pi IPAdress as Gateway address and scan via this Gateway ( Gateway embedded in the PI)
Author:  urbanlarsson [ Mon Jan 28, 2019 1:03 pm ]
Edwin,
then I get "Please check that the gatweay is running"
Author:  Edwin Schwellinger [ Mon Jan 28, 2019 1:41 pm ]
you need to check if the runtime is up and running:
1. by ssh with the following command:
top
2. you could do the same by the updatetool by executing systeminfo.
see screenshot
Author:  urbanlarsson [ Mon Jan 28, 2019 1:55 pm ]
I'm connected and the runtime is started, right?
But I still can't scan the gateway
/U
Author:  Edwin Schwellinger [ Mon Jan 28, 2019 6:21 pm ]
you need to disable 'preticable network names' by
sudo raspi-config
this will solve it I'm pretty sure.
Author:  urbanlarsson [ Tue Jan 29, 2019 3:15 pm ]
It's disabled but I still can't scan network :(
https://www.phpbb.com/
