It is currently Sun Jun 16, 2019 11:50 pm
 Post subject: SPI not working
PostPosted: Thu Jan 03, 2019 10:49 pm
Hello
I want to connect a MCP23S17 device with SPI.
The CSL0 pin is working but the SCLK stays on LOW level
At the Raspberry Board the SPI is enabled,
Any idead what I do wrong?
Regards
Guenter
 Post subject: Re: SPI not working
PostPosted: Fri Jan 04, 2019 8:58 am
a known issue on RASBIAN is:
You need to reduce the max SPI Speed see screenshot
PostPosted: Wed Feb 13, 2019 12:11 pm
Hi, I have some problems using the MCP23S17 chips.
I only connected one chip, but the PLC seems to see them all connected ... How can I eliminate this problem?
Thanks in advance
Massimo
PostPosted: Thu Feb 14, 2019 1:46 pm
I have another question:
using i2c port, if an expansion is disconnected, it is possible to reconnect the expansion.
Using SPI, disconnection of an expansion force me to reboot plc to reconnect to MCP23s17.
Does it is possible to reconnect without reboot the plc?
Users browsing this forum: No registered users and 9 guests
