It is currently Sun Jun 16, 2019 11:36 pm
 Post subject: I2C Address.Bereich
PostPosted: Tue Dec 25, 2018 4:33 pm
Hallo
ich möchte einen BMP280 über die I2C Schnittstelle anschliessen.
Adr: 0x76
Mit SUDO I2CDETECT -y 1 finde ich das Gerät, ABER mit Codesys geht's nicht
Wenn ich online verbunden bin dann ist vor dem BMP280 device ein rotes Dreieck.
Was mache ich falsch?
Kann eventuell mit Codesys die Adresse nicht erreicht werden (0x76)?
Danke für die Hilfe
Guenter
 Post subject: Re: I2C Address.Bereich
PostPosted: Tue Dec 25, 2018 9:09 pm
please check the parameter here:
PostPosted: Tue Dec 25, 2018 9:40 pm
Hi Erwin
I have checked and it looks like ok: I get the info that the BME Bus is not working
hm
Guenter
PostPosted: Tue Dec 25, 2018 9:52 pm
I also have tried to read the whole I2C bus with i2c_master.read but no Response from a device
range: 0x00 up to 0xFF
PostPosted: Wed Dec 26, 2018 8:08 am
if you use 16#76 as address in the configuration, does the BME connector turn into a green circle in the device tree without any call from the pou's?
PostPosted: Wed Dec 26, 2018 9:54 am
Hi Edwin
no green circle. I will check with a oszzi if the ports are working with the i2cmaster.read
Regards
Guenter
PostPosted: Wed Dec 26, 2018 5:53 pm
did you try already this library from the forum for this device?
viewtopic.php?f=23&t=5872&p=18200#p19664`
