It is currently Sat May 25, 2019 8:57 pm
 Post subject: TCP Socket communication
PostPosted: Thu Nov 08, 2018 11:42 am
I am writing a client reading data from another device using TCP socket (STREAM type). The Codesys program runs in PLC PiXtend (Raspberry Pi based PLC). The socket is created and connected successfully. The function sending data (SysSockSend) returns success and 81 bytes of sent data. Subsequent call to of SysSockRecv() return RTS_IEC_RESULT = 529 (Socket has been gracefully closed. No more sends/receives allowed.). What is wrong in my code???
   sDataSend   :STRING;
   sDataRecv   :STRING(4095);
   // IP Socket support
   addressPointer    :POINTER TO SOCKADDRESS;
    address           :SOCKADDRESS;
    ip                  :STRING(16) := '10.0.0.138';
    port               :WORD := 1367;
   iecCreateResult      :RTS_IEC_RESULT;
   iecConnectResult   :RTS_IEC_RESULT;
   iecSendResult        :RTS_IEC_RESULT;
   iecRecvResult        :RTS_IEC_RESULT;
   iecResultClose      :RTS_IEC_RESULT;
   iecResultShutdown   :RTS_IEC_RESULT;
    iecSocketId           :RTS_IEC_HANDLE := 0;
   xiSentBytes           :__XINT;
   xiRecvBytes           :__XINT;
   // Create address
   SysSockInetAddr(ip, ADR(address.sin_addr));
   address.sin_family := SOCKET_AF_INET;
   address.sin_port := SysSockHtons(port);
   addressPointer := ADR(address);
   // Create socket
   iecSocketId := SysSockCreate(SOCKET_AF_INET, SOCKET_STREAM, 0, ADR(iecCreateResult));
   IF iecSocketId = RTS_INVALID_HANDLE THEN
     // Socket creation failed
   ELSE
      // Connect socket
      iecConnectResult := SysSockConnect(iecSocketId, addressPointer, SIZEOF(address));
      // Send data
       xiSentBytes := SysSockSend(iecSocketId, ADR(sDataSend), SIZEOF(sDataSend), 1, ADR(iecSendResult));
      IF xiSentBytes = 0 THEN
         // ... failed
      ELSE
         // Shudown sending data
         iecResultShutdown := SysSockShutdown(iecSocketId, SOCKET_SD_SEND);
         // Receive data
         // THIS CALL FAILS: iecRecvResult = 529
         xiRecvBytes := SysSockRecv(iecSocketId, ADR(sDataRecv), SIZEOF(sDataRecv), 1, ADR(iecRecvResult));
         IF xiRecvBytes = 0 THEN
            // ... failed
         ELSE
            // ... success: process result
   // Close socket after sending/getting data
   iecResultClose := SysSockClose(iecSocketId);
PostPosted: Thu Nov 08, 2018 3:15 pm
Additional information:
When I try to use simple Python script for same operation, it works well. In Codesys I only created same thing using another programming language.
import socket
from datetime import datetime
def netcat(host, port, content):
    s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
    s.connect((host, int(port)))
    s.sendall(content.encode())
    s.shutdown(socket.SHUT_WR)
    result = ""
    while True:
       data = s.recv(4096)
       if not data:
            break
       result = result + data.decode()
    s.close()
    print(result)
HOST="10.0.0.138"
PORT=1367
netcat(HOST, PORT, "{\"id\":1,\"method\":\"sensor-list\",\"params\":[]}")
The Python script reads the result in a loop, my Codesys program reads it in 1 call without the loop. But an expected response is so short, that it must easily fit into a buffer in 1 call. Anyway I tried to read it in a loop too, but the result was 100% same. So the missing loops doesn't seem to be a reason of problem.
PostPosted: Mon Nov 12, 2018 12:52 pm
No answer...… Hmmm..... I tried to rewrite using library Network/CAA Net Base Service 3.5.13.0. The code is below. Connection is OK. Sending data seems to send data successfully. Reading data... after some timeout (10s): "TCP_RECEIVE_ERROR" (code 6012).
PROGRAM POU_TCP_IFACE
VAR_INPUT
   xSend      :BOOL := FALSE;
   sDataSend      :STRING;
   strIPAddr      : NBS.IP_ADDR;
   uiPort      : UINT;
   nwClient       : NBS.TCP_Client;
   nwTCPWrite    : NBS.TCP_Write;
   nwTCPRead    : NBS.TCP_Read;
   sDataRecv      :STRING := '';            // Final result value
   sDataBuff       :STRING(4095);            // Buffer for composing result string
   xBusy      :BOOL := FALSE;
   xSuccess      :BOOL := FALSE;
   xError      :BOOL := FALSE;
   iErrorCode      :INT := 0;
   iStep         :INT := 0;
// If the send command is active and the system is busy, ignore the send request
IF xSend THEN
   IF xBusy THEN
       xSend := FALSE;
IF xSend THEN
   strIPAddr.sAddr := '10.0.0.138';
   uiPort := 1367;
   // Init status variables
   xSend := FALSE;
   xBusy := TRUE;
   xSuccess := FALSE;
   xError := FALSE;
   iErrorCode := 0;
   sDataRecv := '';
   iStep := 0;
   nwClient(xEnable := FALSE);
   nwTCPRead(xEnable := FALSE);
   nwTCPWrite(xExecute := FALSE);
IF xBusy THEN
   CASE iStep OF
      0: // Prepare connection
         nwClient(xEnable := TRUE, ipAddr := strIPAddr, uiPort := uiPort, udiTimeOut := 10000000);
         IF nwClient.xActive THEN
            // Successfuly connected
            iStep := 1;            // JUMP TO SEND DATA
         ELSIF nwClient.xError THEN
            // Error shile connection creation
            nwClient.xEnable := FALSE;
            xError := TRUE;
            iErrorCode := 1;      // Error creating connection: reason - 1
            xBusy := FALSE;
         ELSIF NOT nwClient.xActive AND NOT nwClient.xError AND nwClient.xDone THEN
            xError := TRUE;
            iErrorCode := 2;      // Error creating connection: reason - 2
            xBusy := FALSE;
      1: // Send data
         IF nwTCPWrite.xBusy = FALSE AND nwTCPWrite.xError = FALSE AND nwTCPWrite.xDone = FALSE THEN
            nwTCPWrite.hConnection := nwClient.hConnection;
            nwTCPWrite.pData := ADR(sDataSend);
            nwTCPWrite.szSize := INT_TO_UDINT(LEN(sDataSend));
            nwTCPWrite.udiTimeOut := 10000000;
            nwTCPWrite.xExecute := TRUE;
         IF nwTCPWrite.xDone = TRUE THEN
            // Data IS SENT!
            nwTCPWrite.xExecute := FALSE;
            iStep := 2;         // JUMP TO READ
         ELSIF nwTCPWrite.xError THEN
            // Send data ERROR
            xError := TRUE;
            iErrorCode := 3;      // Data write error
            xBusy := FALSE;
         ELSE
            nwTCPWrite();
      2: // Read data
         nwTCPRead(xEnable := TRUE,
                    hConnection := nwClient.hConnection,
                  szSize := SIZEOF(sDataBuff),
                  pData  := ADR(sDataBuff));
         IF nwTCPRead.xReady AND nwTCPRead.eError = 0 THEN
            IF nwTCPRead.szCount > 0 THEN
               sDataRecv := sDataBuff;
            ELSE
               sDataRecv := '';
            xError := FALSE;
            iErrorCode := 0;      // No error
            xSuccess := TRUE;
            xBusy := FALSE;
         ELSIF nwTCPRead.eError <> 0 THEN
            xError := TRUE;
            iErrorCode := 4;      // Data read error
            xBusy := FALSE;
   END_CASE;
PostPosted: Wed Nov 14, 2018 3:15 pm
I tried to run the program under SIMULATION mode on my development PC. Simultaneously I ran also Wireshark to capture network communication between simu-PLC and the second device. Unfortunately under simulation mode it doesn't work. No socket is opened :-( The function returns zero socket handle but the result error code is also zero. Incredible! Therefore I cannot capture network traffic between PLC and controlled device. Crazy world!!!!!! :-(
