It is currently Wed Feb 20, 2019 10:22 pm
 Post subject: Codesys Crash
PostPosted: Sun Oct 21, 2018 9:18 pm
Every few hours (sometime it every one hour, sometime it once per day) service codesyscontrol crashes without any messages in logs.
So I have to start it from console. I use latest Raspian with kernel 4.14.70-v7+. I use extensive RS485 modbus communication over three USB-Serial converters. USB in low speed mode.
Maybe anybody have any idea?
 Post subject: Re: Codesys Crash
PostPosted: Wed Oct 24, 2018 5:36 pm
May be somebody has any idea?
PostPosted: Wed Oct 24, 2018 6:16 pm
nothing suspect in the logger -
would recommend to check:
Login by ssh:
1. stop the runtime by:
sudo /etc/init.d/codesyscontrol stop
2. start the runtime by:
sudo /opt/codesys/bin/codesyscontrol.bin -d /etc/CODESYSControl.cfg
Then you should see more details... not sure if this will help but you could give this a try.
in case of the stop/Crash - are these ports still accesible from Linux side?
PostPosted: Thu Nov 08, 2018 9:51 am
When I run:
sudo nohup /opt/codesys/bin/codesyscontrol.bin -d /etc/CODESYSControl.cfg &
it shows in the log "No runtime license - running in demo mode". When I open Licensing Manger - Soft Container it reports: "Licensing info is not available. There is no dongle attached to the device".
And it shows in the log: "Logging buffer overflow; log messages dismissed".
