It is currently Wed Feb 20, 2019 11:12 pm
PostPosted: Tue Oct 09, 2018 5:50 pm
hello:
There is some way to extract the name of a function block (from it) to a variable in the same FB.
I do not know if I explained myself very well
Best regards
PostPosted: Wed Oct 10, 2018 7:27 am
Try
{Attribute 'parameterstringof'}
Sent from my Moto G (5S) Plus using Tapatalk
PostPosted: Wed Oct 10, 2018 10:14 am
hello:
Thanks for request, you can write a example to show me some example of the use of that attribute, I do not find any example or help on how to use it.
Best Regards,
PostPosted: Wed Oct 10, 2018 10:34 am
Example:
PostPosted: Wed Oct 10, 2018 10:36 am
The attribute is instance-path and noInit not parameterstringof aI am sorry.
Is mandatory add both attributes: noInit and instance-path
Salut!
PostPosted: Wed Oct 10, 2018 1:27 pm
very thanks,
I have created a function block to see how it works with the following code.
FUNCTION_BLOCK POU_1
VAR_INPUT
in1: BOOL;
in2: BOOL;
VAR_OUTPUT
out1: BOOL;
{attribute 'symbol' := 'none'}
{attribute 'hide'}
{attribute 'instance-path'}
{attribute 'noinit'}
FbName : STRING(255);
if I run that FB in a plc the variable FB_name nor see it.
PostPosted: Wed Oct 10, 2018 8:46 pm
You need another attribute, reflection
https://help.codesys.com/webapp/_cds_pr ... n=3.5.13.0
PostPosted: Thu Oct 11, 2018 8:34 am
very thanks :)
