It is currently Sat May 25, 2019 8:25 pm
PostPosted: Fri Oct 05, 2018 9:39 am
hello,
I am trying use raspberry pi3 +b board. I make codesys test program. Program send to raspberry board run system running. I connected Led cathode to PIN 6 (GND) and led anode to PIN12 (PGIO18). Then I set PGIO18 TRUE level, but led doesn't shine. I don't know where are my mistake. Maybe could give me advice, how solve this problem. I think problem is with raspberry, but I write python program
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
GPIO.setup(12,GPIO.OUT)
for x in range(0,10):
    GPIO.output(12,True)
    time.sleep(1)
    GPIO.output(12,False)
    time.sleep(1)
GPIO.cleanup()
Led is blinking.
GPIOs parameters:
GPIOs IEC parameters:
I attached all my test project.
when program is online
https://www.part.lt/img/5a95e7c981c8345 ... ba8627.jpg
PostPosted: Fri Oct 05, 2018 5:45 pm
just try to revert your project to non device application... then it might work.
PostPosted: Sat Oct 06, 2018 9:28 am
Edwin Schwellinger wrote:
thank, now it is working
Users browsing this forum: No registered users and 8 guests
