CAN Bus example
Kampfwurst
2018-09-17
2021-10-13
  • Kampfwurst - 2018-09-17
    Has someone got the CAN bus with Codesys running?
    I would like to use the can bus to communicate with my tennsy or arduino board.
    Thanks Chris
    eschwellinger - 2018-09-18
    either in case this a CANopen device ( added by eds file)
    https://store.codesys.com/canopen-example.html
    or for Layer2 communication
    https://store.codesys.com/en/canbus-example.html Description
    Last edit: i-campbell 2021-10-13
    • vvora - 2021-10-13
      Can you check the second link. I could not open it. Thanks
      • i-campbell
        i-campbell - 2021-10-13
        fixed :)
          Thanks. It downloaded as a package, is there a way to retrieve a project file from it or a way to open the project file for the example?
  • Kampfwurst - 2018-09-22
    welche Hardware wird da vom unterstützt? Würde das gerne für die Kommunikation zwischen einem Mikrocontroller und dem Raspberry einsetzen.
    SN65HVD230 oder der MCP2515?
