I am facing a similar problem like you. I have downloaded the MCP4725 library from this forum. No matter what value I put in the MCP4725.xdacIn, the voltage is always at 0V.
I am using a hardware that has raspberry pi core. The Codesys version I am using is Ver3.5 SP17 Patch3. I tried putting 97 in I2C Bus Parameters for MCP4725 (screenshot = Issue DAC 2) but still I am facing the same issue.
I have been using ADC in I2C mode as well. I didn't face any problem with that as I got an example code for it. Could this be because I am using ADC and DAC with I2C at the same time?
Could you please help me out? I am attaching the screenshots as well. It is also mentioned in the library method file 'AfterReadInputs' (screenshot = Issue DAC 3) that we must change wInfo[0] to 16#60 from 16#40 if we want to write the values into DAC register and EEPROM. I guess these files are write protected. Do I have to change this value and if so how? I am unable to do that.
Hi All,
Can anyone help me?
I installed the MCP4725 library found here on the forum in the dedicated section.
Everything seems connected and configured correctly:
MCP4725.xdacIn
Thank you for your attention
Bye
Solved!
61 is on HEX format. On Codesys must be wrote in UINT
61HEX = 97UINT
Hi!
iDacValue : INT;
MCP4725.xdacIn := iDacValue; (screenshot = Issue DAC 1)
Looking forward to your reply.
Thanking you in advance.
Best Regards!
