Codesys writing csv-file to Raspberry/ RPi directory
SpeedyG
2018-08-14
2021-06-07
  • SpeedyG - 2018-08-14
    Hi there, (English and German are alright)
    I am feeling like I am missing something small, but I still cannot find it:
    I am doing an internship and have to solve the problem asap (almost at the end). It would be a big relieve if you could help me! Here the problem:
    I am using Codesys V3.5 SP11 Patch 3+ and I am working with Codesys Control for RPi
    My aim is to create a csv-file in Codesys and save it on the sd card from the RPi. To make things easier I have two programs running, one on
    1) Codesys Control Win V3 and one on
    2) Codesys Control for RPi.
    The code is the same (very simplified), only the machine and directory are different.
    The program is working on the Windows machine. It is creating the file and writing in it the information I give it in the code. On the RPi however the program is running (no Error?!), but it isn't writing a file. My thinking was that it has something to do with the directory, but after researching over one week I still haven't found the right information.
    I have attached the program and the subprogram so you can have a look on it. (not all variables are used bc I shortened the program)
    One of the directories I tried is: 'cd \home\pi\Downloads\test.csv' (probably totally wrong)
    Thank you so much for your help!!
    SpeedyG
    VAR       bWrite         BOOL
    VAR      pEnd         POINTER TO STRING
    VAR      resultdata_csv      ARRAY[1..400000] OF BYTE
    VAR      handleFile      DWORD
    VAR      dwWritten      DWORD
    VAR      szSeperator      STRING(1)            ';'
    VAR      iCounter1      INT
    VAR      Copy_of_bWrite      BOOL            TRUE
    VAR      FilePathAndName      String            'cd \home\pi\Downloads\test.csv
    VAR      CRLF         STRING(2)         '$R$N'
    VAR      LF         String(1)         '$N'
    VAR      Copy_of_resultdata_csv   ARRAY[1..400000] OF BYTE
    VAR      big         DINT
    VAR      i         DINT
    VAR      z         DINT
    VAR      zahl         REAL
    VAR      Copy_of_pEnd      POINTER TO STRING
    VAR      fopen         FILE.Open
    VAR      fwrite         file.Write
    VAR      fclose         file.Close
    (* ---------------------------- Fill Head Data -------------------------------- *)
    IF bWrite THEN
       pEnd := ADR(resultdata_csv);
       pEnd := StrCatPtr('987654321', pEnd);
    fopen(
       xExecute:= TRUE,
       xDone=> ,
       xBusy=> ,
       xError=> ,
       sFileName:= FilePathAndName,
       eFileMode:= 0,
       xExclusive:= ,
       eError=> ,
       hFile=> handleFile);
    fwrite(
       xExecute:= fopen.xDone,
       xAbort:= ,
       udiTimeOut:= ,
       xDone=> ,
       xBusy=> ,
       xError=> ,
       xAborted=> ,
       hFile:= handleFile,
       pBuffer:= ADR(resultdata_csv),
       szSize:=   pEnd - ADR(resultdata_csv) ,
       eError=> );
       fclose(
       xExecute:= fwrite.xDone,
       xDone=> ,
       xBusy=> ,
       xError=> ,
       hFile:= handleFile,
       eError=> );
       IF  fclose.xDone
          THEN
            bWrite:= FALSE;
          END_IF
    END_IF
    StrCatPtr (FUN).txt [320 Bytes]
    PLC_PRG (PRG)_short.txt [1.37 KiB]
  • johnlee - 2018-08-27
    cd \home\pi\Downloads\test.csv -> /home/pi/Downloads/test.csv
  • SpeedyG - 2018-08-28
    Ouch, that hurts. I guess it was too obvious. -.- Thank you @johnlee.
  • galexis - 2021-06-01
    I try to use your code, but it work only one time. I can't to write a other line on csv: csv doesn't change. I need to clean code and reload code on Rpi: it works, but first line of csv is replace. What is the problem ?
    Thank for your help.
  • Ingo
    Ingo - 2021-06-03
    Didn't try it, but i expect two problems from the code:
    1st:
    fopen(
       xExecute:= TRUE,
    xExecute is not toggled, so it is only executed once. maybe this would help:
    fopen(
       xExecute:= bWrite,
    2nd:
    eFileMode:= 0,
    if you want to append a line, you need to set the filemode to "append".
    But this was just the first impression, on first sight.
    Cheers,
    Ingo
  • galexis - 2021-06-03
    yes, if file already exist : efilemode had to be 3 and if it doesn't exist efilemode had to be 0.
    I see fopen.xExecute...
    I do:
    PROGRAM POU_RPi
    VAR
        bWrite: BOOL;
        pEnd: POINTER TO STRING;
        resultdata_csv: ARRAY[1..400000] OF BYTE;
        Hfile: DWORD;
        //szSeperator: STRING(1):=';';
        FilePathAndName: STRING:= '/home/pi/Downloads/test.csv';
        CRLF: STRING(2):='$R$N';
        LF: STRING(1):= '$N';
        fopen: FILE.Open;
        fopenadd: FILE.Open;
        fwrite: file.Write;
        fclose: file.Close;
        test: INT :=1;
        NumAction: INT;
        code_erreur: INT;
    END_VAR
    (* ---------------------------- Ecrire les data dans le CSV-------------------------------- *)
    IF bWrite THEN
        pEnd := StrCatPtr('Test n°', pEnd);
        pEnd := StrCatPtr(INT_TO_STRING(test), pEnd);
        pEnd := StrCatPtr(Lf, pEnd);
        //pEnd := StrCatPtr(CRLF, pEnd);
        CASE NumAction OF
        0: ;
        1:  (*Ouvrir le fichier*)
            //en mode ajout
            fopenadd.sFileName:=FilePathAndName;
            fopenadd.eFileMode:=FILE.MODE.MAPPD;
            fopenadd.xExclusive:=TRUE;
            fopenadd( xExecute:=TRUE);
            //Le fichier existe
            IF fopenadd.xDone THEN
                Hfile:=fopen.hFile;
                NumAction:=2;
            END_IF
            //Erreur
            IF fopenadd.xError AND fopenadd.eError<>5104 THEN
                code_erreur:=4;
                NumAction:=3;
            END_IF
            //Le fichier n'existe pas, créer
            IF fopenadd.xError AND fopenadd.eError=5104 THEN
                fopen.sFileName:=FilePathAndName;
                fopen.eFileMode:=FILE.MODE.MWRITE;
                fopen.xExclusive:=TRUE;
                fopen( xExecute:=TRUE);
                IF fopen.xError THEN
                END_IF
                NumAction:=2;
            END_IF
        2:  (* Ecrire dans le fichier*)
            fwrite.hFile:=Hfile;
            fwrite.pBuffer:=ADR(resultdata_csv);
            fwrite.szSize:= pEnd - ADR(resultdata_csv);
            fwrite.udiTimeOut:=100000;       (* 100ms Timeout *)
            fwrite( xExecute:=TRUE);
            IF fwrite.xDone THEN
                Hfile:=fopen.hFile;
                NumAction:=3;
            END_IF
            IF fwrite.xError THEN
                code_erreur:=6;
                NumAction:=3;
            END_IF
        3:  (* Fermer le fichier *)
            fclose.hFile:=Hfile;
            fclose( xExecute:=TRUE);
            IF fclose.xDone THEN
                NumAction:=3;
            END_IF
            IF fclose.xError THEN
                //code_erreur:=10;
                bWrite:= FALSE;
            END_IF
        END_CASE
            code_erreur:=0;
            bWrite:= FALSE;
            test:=test+1;
        END_IF
    ELSE
        fopen(xExecute:=FALSE);
        fclose(xExecute:=FALSE);
        fwrite(xExecute:=FALSE);
        NumAction:=1;
    END_IF
    I test to open file on efilemode =3, if return error code= 5104 (file not exist), I open file in efilemode=0.
    Open create well file when not exist, but when I want to write on, write return error code = HANDLE INVALID.
    What is the reason ?
    Thanks a lot.
  • dkugler - 2021-06-03
    the handle is invalid, because your program write nothing to Hfile in this case 😉
    Last edit: dkugler 2021-06-03
  • galexis - 2021-06-04
    I make some changes but don't work more:
    PROGRAM POU_RPi
    VAR
        bWrite: BOOL;
        Hfile: DWORD;
        fopen: FILE.Open;
        fwrite: file.Write;
        fclose: file.Close;
        test: INT :=1;
        NumAction: INT;
        code_erreur: INT;
    END_VAR
    IF bWrite THEN
        CASE NumAction OF
        0: ;
            //en mode ajout
            //Le fichier existe
                Hfile:=fopenadd.hFile;
                NumAction:=2;
            END_IF
            //Erreur
                code_erreur:=4;
                NumAction:=3;
            END_IF
                END_IF
                IF fopen.xDone THEN
                    Hfile:=fopen.hFile;
                END_IF
                NumAction:=2;
            END_IF
                Hfile:=fwrite.hFile;
                NumAction:=3;
            END_IF
                code_erreur:=6;
                NumAction:=3;
            END_IF
                code_erreur:=10;
                bWrite:= FALSE;
            END_IF
        END_CASE
            code_erreur:=0;
            bWrite:= FALSE;
            test:=test+1;
        END_IF
    ELSE
        NumAction:=1;
    END_IF
  • wollvieh
    wollvieh - 2021-06-04
    i change a little bit and tested it with winV3
    PROGRAM POU_RPi
    VAR
    bWrite: BOOL;
    Hfile: DWORD;
    FilePathAndName: STRING:= 'c:/temp/test.csv';
    fopencreate : FILE.Open;
    fopen : FILE.Open;
    fwrite: file.Write;
    fclose: file.Close;
    test: INT :=1;
    NumAction: INT;
    code_erreur: INT;
    NumActTrig : R_TRIG;
    END_VAR
    ( ---------------------------- Ecrire les data dans le CSV-------------------------------- )
    fopencreate(
    xExecute:= (NumAction=100),
    xDone=> ,
    xBusy=> ,
    xError=> ,
    eFileMode:= FILE.MODE.MWRITE,
    xExclusive:= ,
    eError=> ,
    hFile=> );
    fopen(
    xExecute:= (NumAction=1),
    xDone=> ,
    xBusy=> ,
    xError=> ,
    eFileMode:= FILE.MODE.MAPPD,
    xExclusive:= ,
    eError=> ,
    hFile=> );
    fwrite(
    xExecute:= (NumAction=3),
    xAbort:= ,
    udiTimeOut:= 10000,
    xDone=> ,
    xBusy=> ,
    xError=> ,
    xAborted=> ,
    hFile:= Hfile,
    szSize:= pEnd - ADR(resultdata_csv),
    eError=> );
    fclose(
    xExecute:= (NumAction=5),
    xDone=> ,
    xBusy=> ,
    xError=> ,
    hFile:= Hfile,
    eError=> );
    NumActTrig(CLK:= bWrite , Q=> );
    IF NumActTrig.Q
    THEN
     NumAction :=1;
    END_IF
    CASE NumAction OF
    0: bWrite := FALSE;
        //en mode ajout
        //Le fichier existe
        IF fopen.xDone THEN
            Hfile:=fopen.hFile;
            NumAction:=2;
        END_IF
        //Erreur
        IF fopen.xError AND fopen.eError<>5104 THEN
            code_erreur:=4;
            NumAction:=999;
        END_IF
        IF fopen.eError = 5104
        THEN
            NumAction:=100;
        END_IF
    2: NumAction:=3;
    3:  (* Ecrire dans le fichier*)
            NumAction:=4;
        END_IF
            code_erreur:=6;
            NumAction:=999;
        END_IF
    4: NumAction:=5;
    5:  (* Fermer le fichier *)
            code_erreur:=10;
            bWrite:= FALSE;
            NumAction:=999;
        END_IF
          NumAction:=0;
          code_erreur:=0;
          test:=test+1;
    END_IF
    100: //create file
        //en mode ajout
        //Le fichier existe
        IF fopencreate.xDone THEN
            Hfile:=fopencreate.hFile;
            NumAction:=101;
        END_IF
        //Erreur
        IF fopencreate.xError AND fopencreate.eError<>5104 THEN
            code_erreur:=4;
            NumAction:=999;
        END_IF
        IF fopencreate.eError = 5104
        THEN
            NumAction:=100;
        END_IF
    101 : NumAction:=3;
    END_CASE
  • galexis - 2021-06-07
    It work fine.
    Thank you very much for your help.
