Ethernet/Ip Modules -> No Driver found
BenGor
2018-07-25
2018-07-26
  • BenGor - 2018-07-25
    I am using a Raspberry Pi with Codesys to Communicate with a Allen Bradley PLC. For my communication I need 206 Input Bytes and 54 OutputBytes. I used a instruction from this forum to set up my communication. So I added a Ethernet/Ip Adapter and 4 Input Byte Modules, 52 DWord Input Modules aswell as 25 Output Word Modules and 4 Output Byte Modules. Everything worked fine in my implementation phase until I wanted to add the last 10 Dword InputBytes. I get a Error so that the EthernetIp Adapter wont work. Status of those not working Modules is "No driver found". Also I get the Error: "EtherNet/Ip Adapter could not be configured. Error Code: 53. Hope someone could help me.
    IMG: EthernerAdapter.PNG
  • Thomas - 2018-07-26
    Dear BenGor,
    Your problem is that the max. modules is set to 64 as default.
    You must add the "CIP Object"-library as toplevel library in your project and set the parameter "MAX_NUMBER_PROXIED_ASSEMPLIES" to 74 or 75.
    And than you must change the max. modules in the "IoDrvEthernetIPAdapter".
    Good Luck
    IMG: EthernetIpModules.png
    IMG: CIP.png
