problem running Raspberry Pi
AndyCoates
2018-06-26
2018-06-27
  • AndyCoates - 2018-06-26
    Can anyone help.
    I am trying to run the attached code but with no luck.
    I am using Codesys V3.5 sp12 patch4 64 bit, Codesys for Raspberry Pi 3.5.12.30
    I can connect and download but that seems to be it, I must be missing something quite simple.
    I don't seem to have the project files that should have downloaded with the main programme, in particular the PiFace example. Were can I get that now?.
    Thanks for any help.
    Untitled1.project [159.12 KiB]
    eschwellinger - 2018-06-27
    if you install the Pi package from CODESYS store you should be able to find the examples here:
    "c:\Users\<yourwindowsusername>\CODESYS Control for Raspberry PI\3.5.12.10\Examples\PiFaceIoDrv.project" </yourwindowsusername>
  • AndyCoates - 2018-06-27
    Thanks, I have found them now.
    still can`t figure out what I have wrong
