EthernetIP Adapter Bus is not running
BenGor
2018-06-11
2018-06-11
  • bisquit - 2018-06-11
    BenGor hat geschrieben:
    Hey there,
    I am trying to configure my Raspi as a Ethernet Adapter. Following the instruction from https://forum.codesys.com/viewtopic.php?t=7237, i managed to extract a eds file etc. My Problem is that I can't get it started. Codesys always tells me that the bus is not running. I set Main Task as my task in the Ethernet adapter. But any other setting won'twork either. Hope anyone could help me? Thank!
    I don't mean to hijack your thread but im having some trouble with Ethernet/IP as well.
    l viewtopic.php?f=21&t=8897 l
    What does it say when you view "status"?
    In my case the bus will run fine when there's no I/O configured. When I add it manually with the information I get from the EDS it won't work.
    The eds file opens fine in different programmers.
    IMG: 2018
  • BenGor - 2018-06-11
    It says "Not Running"
    IMG: Error.png
