BenGor hat geschrieben:
Hey there,
I am trying to configure my Raspi as a Ethernet Adapter. Following the instruction from https://forum.codesys.com/viewtopic.php?t=7237, i managed to extract a eds file etc. My Problem is that I can't get it started. Codesys always tells me that the bus is not running. I set Main Task as my task in the Ethernet adapter. But any other setting won'twork either. Hope anyone could help me? Thank!
I don't mean to hijack your thread but im having some trouble with Ethernet/IP as well.
l viewtopic.php?f=21&t=8897 l
What does it say when you view "status"?
In my case the bus will run fine when there's no I/O configured. When I add it manually with the information I get from the EDS it won't work.
The eds file opens fine in different programmers.
Hey there,
It says "Not Running"
