It is currently Wed Apr 24, 2019 7:38 am
PostPosted: Fri May 25, 2018 9:43 am
Hey guys,
I'm having some trouble declaring the variables in my project.
I want to be able to set/reset the bits in a word and be able to reset the whole word at once.
So far i got it working fine at %MW0, but when I try the same at any other adress it wont work.
Can somebody help me a bit?
PostPosted: Sat May 26, 2018 9:00 pm
Try:
MyMW:pointer to dword;
MyMW:=adr(mx0);
MyMW[0] is mx0
MyMW[1] is mx1
Setting full
MyMW[1]:=16#B1
For example
Sent from my Moto G (5S) Plus using Tapatalk
PostPosted: Sun May 27, 2018 10:26 am
I think a Union of 16 BITs (not BOOL) and a WORD is a better way to achieve this.
PostPosted: Mon May 28, 2018 10:06 am
Josep M. Rams wrote:
Try:
MyMW:=adr(mx0);
MyMW[0] is mx0
MyMW[1] is mx1
Setting full
MyMW[1]:=16#B1
For example
Thank you for the suggestions guys! A union seems to work quite well.
How do I add a comment to a bit in a union?
For example: bit 1 in union 1 should be called "valve 5". And bit 1 in union 2 should be named different.
PostPosted: Mon May 28, 2018 10:59 am
Include a STRUCT in your union with the names you need. It sounds like this can replace the BITs
PostPosted: Mon May 28, 2018 11:18 am
When I re-use a union by declaring the same union under different name. Then the bits will have the same name, right?
Maybe my intentions aren't clear:
For my program i need my bits in groups of 16, like a word. I want to set/reset these bits individually or all at once.
I need a whole bunch of these groups. I'd like to add a comment to every individual bit in a group. (With different comments in different groups)
A fixxed adress is not necessary.
I need a fast/simple method of creating these groups
This is what I've done so far:
TYPE STR_BITS :
STRUCT
   x00 : BIT;
   x01 : BIT;
   x02 : BIT;
   x03 : BIT;
   x04 : BIT;
   x05 : BIT;
   x06 : BIT;
   x07 : BIT;
   x08 : BIT;
   x09 : BIT;
   x10 : BIT;
   x11 : BIT;
   x12 : BIT;
   x13 : BIT;
   x14 : BIT;
   x15 : BIT;
END_STRUCT
END_TYPE
TYPE UNION_BITS_WORD :
UNION
   strBits : STR_BITS;
   wWord : WORD;
END_UNION
END_TYPE
   union1 : UNION_BITS_WORD;
   union2 : UNION_BITS_WORD;
PostPosted: Tue May 29, 2018 7:38 am
I like the way how its working now with the struct and the union.
Can somebody explain how I add a comment to one specific bit in one specific word?
Something along the lines of this?
GVL.W120.Wstruct.x00 // Word 120, Bit 00, Valve 5
