It is currently Thu Aug 22, 2019 1:18 pm
 Post subject: Turn off raspberry
PostPosted: Fri May 18, 2018 11:09 am
Good morning,
I'm pretty new to codesys and the programming side of raspberry.
I'm trying to power off my raspberry using my HMI.
I've found some other examples, but I couldnt get them to work:
viewtopic.php?t=8638 - Keep getting syntax errors
viewtopic.php?f=21&t=5714 - No errors, it just doesnt power off
I'm using ladder logic to program the raspberry.
Can somebody explain how to do it?
 Post subject: Re: Turn off raspberry
PostPosted: Sun May 20, 2018 9:52 pm
http://forum.codesys.com/viewtopic.php?f=23&t=6247&p=12699#p12699
I use this:
PROGRAM power
   Result: UDINT;
IF GlobalVariables.resetFromVISU THEN
   GlobalVariables.power_led := FALSE;
   _ (pszComand:='sudo reboot' , pResult:= ADR(Result));
IF GlobalVariables.poweroffFromVISU THEN
   _ (pszComand:='sudo poweroff' , pResult:= ADR(Result));
and
[SysProcess]
Command=AllowAll
in CODESYSControl_User.cfg file
I hope this will help.
When I write in code syntax _SysProcess_Execute_Command_ after submit I see only "_" why?
PostPosted: Tue May 22, 2018 1:47 pm
I use this:
PROGRAM power
   Result: UDINT;
and
[SysProcess]
Command=AllowAll
I've got it all working now.
Thank you for your help!
