Ethercat Lxm32m movevelocity speed control overshoot every 5 seconds
mATTO
2018-05-09
2023-08-17
  • mATTO - 2018-05-09
    Hello, I have RPI-1 B @ 1000 MHz frequency
    Linux raspberrypi 4.4.9-rt17+ #2 PREEMPT RT Thu May 12 00:18:09 CEST 2016 armv6l GNU/Linux
    CODESYS Control for Raspberry PI 3.5.12.10
    when the axis is running in continous_motion with mc_movevelocity, speed overshoot occurs every 5 seconds, I cannot find the cause, seeking it sinve 3 days
    thank you in advance for your help
    BR Ozcan
    IMG: 180509_Ethercat_LXM32M.PNG
  • josepmariarams - 2018-05-09
    Have you enabled dc clock?
  • mATTO - 2018-05-10
    Josep M. Rams hat geschrieben:
    Of course Josep dc clock is enabled, if not the communication will be problematic
  • eschwellinger
    eschwellinger - 2018-05-10
    do you see this 5s peaks in the cyclic tests of rt_preempt too?
  • mATTO - 2018-05-11
    it's very interesting, when rt-tests is running it never occurs but when the test is finished, speed overshoot starts again
    IMG: htop.PNG
    IMG: rt_tests.PNG
  • josepmariarams - 2018-05-12
    The cpu works at fixed frequency?
    Enviat des del meu Aquaris M5.5 usant Tapatalk
