TOF RST and ET
alverman
2018-05-01
2018-05-01
  • alverman - 2018-05-01
    hello, I need a TOF that has RST and ET
    OSCAT has a TOF with RST but does not have ET
    Standard TOF has ET but has no RST
    How can I solve ?
    Thanks, Alberto
  • Lo5tNet - 2018-05-01
    Just make your own: (Should work but needs to be tested)
    FUNCTION_BLOCK TOF_Advanced
    VAR_INPUT
        IN:BOOL;
        PT:TIME;
        RST:BOOL;
    VAR_OUTPUT
        ET:TIME;
        Q:BOOL;
        tStartTime : TIME;
        tCurrentTime : TIME;
    //Read system time
    tCurrentTime := TIME();
    //Set Q based off IN and PT
    IF RST THEN
        Q := FALSE;
        ET := T#0MS; //You can reset ET here also if wanted
    ELSIF IN THEN
        Q := TRUE;
        ET := T#0MS;
        tStartTime := tCurrentTime;
    ELSIF tCurrentTime - tStartTime >= PT AND Q THEN
        ET := tCurrentTime - tStartTime;
        Q := FALSE;
        tCurrentTime := T#0MS;
    ELSIF Q AND NOT IN THEN
    IMG: TOF_Advanced.PNG
    WooooooW
    Work very fine
