Hi everyone,
With Linux/Jessie on the Raspberry, I can without problem "scan network" and "connect" the Pi to Codesys...
But I'm trying now a new kernel 4.4.9-rt17-v7 (patch Preempt_rt) and I face difficulties.
Via wifi the Pi is well connected to the router (I've got a IP and internet) and
with I got the right of the Pi's connection:
I can even reboot the Pi with ""
but I can't connect the Raspberry to Codesys !
Do someone knows why ? What has changed with the new kernel ?
Thank you in advance.
Hi everyone,
could you give us results of (Login by ssh / putty)
cat /tmp/codesyscontrol.log
or try:
sudo /etc/init.d/codesyscontrol stopsudo /etc/init.d/codesyscontrol start
Thanks Edwin,
I did and sudo replied: unknown command
runtime was obviously not correctly installed. Now it's fixed and I'll try to get the servo in motion ...
Best Regards
