no connection to target (Raspberry not found)
2018-04-24
2018-04-26
  • massaproduxy - 2018-04-24
    Hi everyone,
    With Linux/Jessie on the Raspberry, I can without problem "scan network" and "connect" the Pi to Codesys...
    But I'm trying now a new kernel 4.4.9-rt17-v7 (patch Preempt_rt) and I face difficulties.
    Via wifi the Pi is well connected to the router (I've got a IP and internet) and
    with I got the right of the Pi's connection:
    I can even reboot the Pi with ""
    but I can't connect the Raspberry to Codesys !
    Do someone knows why ? What has changed with the new kernel ?
    Thank you in advance.
    IMG: System infos RPi.JPG
  • eschwellinger
    eschwellinger - 2018-04-25
    could you give us results of (Login by ssh / putty)
    cat /tmp/codesyscontrol.log
    or try:
    sudo /etc/init.d/codesyscontrol stopsudo /etc/init.d/codesyscontrol start
  • massaproduxy - 2018-04-26
    Thanks Edwin,
    I did and sudo replied: unknown command
    runtime was obviously not correctly installed. Now it's fixed and I'll try to get the servo in motion ...
    Best Regards
