Hi I am trying to polling MOXA E1242 device by Modbus. The attached file is my project. I am sure the modbus tcp master fieldbus work fine.
I could see the Modbus polling Ethernet sockets in Wireshark tool that on Raspberry Pi. I have add variables and mapping to Modbus command.
But I can not see the variable value changed. It's always zero.
How should I setting to make the modbus polling data mapping to variables? Thanks.
Thanks. It's work. But I have more questions.
1. I can't get two variable value in the same ModbusTCPSlave Channel. see the attached file ModbusTCPMaster_Value.jpg.
2. Where can I see the memory mapping value like %IW0, %IX0.0 ...
3. I only could login to Raspberry Pi and start this project once. If I logout and then login again to start project always got "ModbusTCPSlave : Bus Failure" Error.
CODESYS 3.5 SP12 Patch 2 + CODESYS Control for Raspberry Pi SL 3.5.12.10
Daniel
Webvisu.zip [233.39 KiB]
CODESYS does only update variables which are used in the pou's.
This is a fieldbus independent feature.
So either use your mapped varibale or change to 'enabled2 - always update'
Hi Edwin,
Daniel
