It is currently Mon Aug 26, 2019 5:37 am
PostPosted: Thu Jan 25, 2018 6:25 pm
I have several RPi running Codesys and I would like to know if I could update my PLC software (running with codesyscontrol service) without the Codesys Development System on my working station.
The idea is to run a shell script on the RPi that stop codesyscontrol, then it could copy some files to change the PLC software (or something else) and then restart codesyscontrol service.
Is it possible?
Best regards,
Vincent
PostPosted: Thu Jan 25, 2018 7:20 pm
Yes, it is possible. You need something like this:
#!/bin/bash
CURRDIR=`dirname $0`
systemctl stop codesyscontrol
while kill -0 `pidof codesyscontrol` 2> /dev/null; do sleep 1; done
for dir in /var/opt/codesys//PlcLogic/*; do
    [ -z "${dir##*trend*}" ] && continue
    rm -rf "$dir"
done
if [ -f $CURRDIR/PlcLogic.zip ]; then unzip $CURRDIR/PlcLogic.zip -qo -d /var/opt/codesys; fi
sync
systemctl start codesyscontrol
PlcLogic.zip created manually using Codesys (save boot application).
PostPosted: Fri Jan 26, 2018 2:00 pm
why not just use the official way to do this?
sudo dpkg -i codesyscontrol_arm_raspberry_V3.5.12.0.de
will update the plc runtime Version and bootprojekt runs imidiately in the new version... if already on the system running before the update
To update your application means-> update the content of /var/opt/codesys/PlcLogic/ (which are the application files)
Last edited by Edwin Schwellinger on Fri Feb 16, 2018 6:24 pm, edited 1 time in total.
PostPosted: Fri Feb 16, 2018 6:10 pm
Hey,
Sorry for the delay and but thank you for your answer.
I will try it soon when I have the opportunity.
Vincent
PostPosted: Sun Apr 15, 2018 4:06 pm
Hi Viacheslav
Nice Script, but how do you save the boot project as a PlcLogic.zip file.
I can only save the file as a Application.app file which I can not open as a zip-file ???
I am doing as discribed in the online help.
Best regards.
Peter
