Author |
Message |
Johan10
PostPosted: Sat Apr 14, 2018 9:58 pm |
Hello everyone, I’ve made a sensor for my Robot to detect obstacles. Here is my schematic connexion, and python code. But does someone knows how to make it work with Codesys in ST langage? Thank’s a lot. I’ll be very grateful for your help.
import RPi.GPIO as GPIO import time
GPIO.setmode(GPIO.BCM)
print "+-----------------------------------------------------------+" print "| Mesure de distance par le capteur ultrasonore HC-SR04 |" print "+-----------------------------------------------------------+"
Trig = 23 # Entree Trig du HC-SR04 branchee au GPIO 23 #trig input Echo = 24 # Sortie Echo du HC-SR04 branchee au GPIO 24 #echo output
GPIO.setup(Trig,GPIO.OUT) GPIO.setup(Echo,GPIO.IN)
GPIO.output(Trig, False)
repet = input("Entrez un nombre de repetitions de mesure : ") #Enter a number of repetition
for x in range(repet): # On prend la mesure "repet" fois #we take mesure « repet » time
time.sleep(1) # On la prend toute les 1 seconde #we take it each 1sec
GPIO.output(Trig, True) time.sleep(0.00001) GPIO.output(Trig, False)
while GPIO.input(Echo)==0: ## Emission de l'ultrason #Emits Ultrasonic debutImpulsion = time.time()
while GPIO.input(Echo)==1: ## Retour de l'Echo # Return Echo finImpulsion = time.time()
distance = round((finImpulsion - debutImpulsion) * 340 * 100 / 2, 1) ## Vitesse du son (sound speed)= 340 m/s
print "La distance est de : ",distance," cm" #the distance is
GPIO.cleanup()
Top |
