It is currently Tue Jan 28, 2020 7:33 am
 Post subject: initialize variables
PostPosted: Wed Jan 16, 2019 1:57 pm
Dear all,
I have tried to initialize my variables ( init: BOOL := 1; ).
This works the first time I run the program.
If I stop the program and run it again (or if I build again, login and start the program) its not initialized again.
How can I fix this ?
I would like to initialize my variable everytime I start the program.
 Post subject: Re: initialize variables
PostPosted: Wed Jan 16, 2019 11:03 pm
Hello
Only a hot Reset or a cold Reset intialize variables.
When you build your program, login and start it, it's like a Reset.
I think you have to write a small program to initialize your variables each time you simply run the program.
For exemple :
(*GVL declaration*)
VAR
xInitialisation_OK :BOOL; (*This variable is FALSE each time your PLC start*)
END_VAR
(*Begin of your program*)
IF NOT xInitialisation_OK then (*IF xInitialisation_OK is FALSE, it's the first cycle of scrutation*)
xvariable1:= ... ; (*write the initial value you want *)
xvariable2:=... ;
xInitialisation_OK :=TRUE; (*Initialization is finish*)
END_IF
You can also write this program in a "StartDone" System Event.
BR :D
PostPosted: Thu Jan 17, 2019 5:31 pm
Thank you !
I have fixed it with the StartDone Event.
Thanks for the reply..
Grz
Thomas
Users browsing this forum: esih and 3 guests
