It is currently Tue Mar 19, 2019 7:52 pm
PostPosted: Thu Mar 08, 2018 5:32 pm
I am trying to measure temperature using a MCP3008 to convert the values. The only values I get from it are 0 or 255.
I check the wiring a few times so I doubt that's the problem. I have setup the SPI master and MCP3008.
It only gives 255 when the input to channel 0 is 1V higher than Vref.
PostPosted: Thu Mar 08, 2018 9:25 pm
Can you post your setup?
A photo or a sketch (e.g. with "Fritzing").
PostPosted: Fri Mar 09, 2018 10:38 am
I set up the mcp3008 the same as the picture. I am using different sensors though.
I tried testing it with a potentiometer and that's how I found out it gives 255 if the channel input is 1 volt higher than Vref and 0 if its less.
I am using a raspberry pi 3 model B.
PostPosted: Fri Mar 09, 2018 11:57 am
if you are working with Rasbian Stretch from 11-29-2017 Version (current Version)
there seems a Problem with the maxSPI Speed.
You can reduce here the SPImax Speed, then it should work. (sure depends on your used Versions of Rasbian)
https://www.raspberrypi.org/forums/view ... 4&t=207412
Last edited by Edwin Schwellinger on Sun Mar 11, 2018 7:13 pm, edited 1 time in total.
PostPosted: Fri Mar 09, 2018 12:21 pm
Thanks for the reply.
That seems to have fixed the problem.
I now get a range of readings. similar to what I expected.
Thank you.
Users browsing this forum: drsumruay and 6 guests
