I have done two different projects, one with MCP23017 board (i2C) and the second with DS18B20 temperature sensor. For each project the Raspberry works well, but when I put both projects in one, the cycle time goes to 8 second instead of 10ms that I reach with the separate projects.
Could someone help me?
Thanks in advance
Thanks in advance
this example project from the application section (in this Forum) should point you in the right direction:
l viewtopic.php?f=23&t=6247&p=16920#p16920 l
