RPi + Codesys: how to obtain a graceful shutdown of the system
mikeardy
2018-02-19
2018-02-19
  • mikeardy - 2018-02-19
    I'm searching for a solution to send to the system the halt command to put it in normal graceful shutdown.
    Is there some possibilities to do that via Codesys?
    Thank a lot.
  • DavidCozens - 2018-02-19
    Hi Mike,
    Have a look at the SysProcess library, it gives you what you require.
    There is already a post on this topic that walks you through how to reboot. See l viewtopic.php?t=5714 l
  • Ingo
    Ingo - 2018-02-19
    Or, if you want to do it manually through the IDE, you can use:
    Tools -> Update Raspberry Pi -> Shutdown
