Need help for Modbus TCP beetwen RPI and PLC
groy
2018-02-10
2018-02-11
  • groy - 2018-02-10
    Hi everyone,
    I try to use Modbus TCP beetwen RPI and PLC and I also make init with "Modbus Slave Init" and the value was transfered to PLC. I try read holding register at 0x0000 and all status in codesys "device" is ok but why my value is always zero even though I change the value. I used another tool as Modbus TCP master but the value is good, could anyone help me for this problem?
    Regards
    Roy
    IMG: MB_RPI.jpg
    eschwellinger - 2018-02-10
    You need to call the mapped variables somewhere in the Pou's if not called tge values will not updated.
  • groy - 2018-02-11
    Hi Edwin,
    Thank you for your explanation, I don't know if it must process in Pou
    Roy
