Hi Ivan,
I would use the available driver for thw EL2521
But even if you use a Raspberry PI without realtime patch, this drivers might work,
check with this Settings from the screenshot
( & an enbaled DC)
check this example:
"c:\Program Files\3S CODESYS\CODESYS\Projects\SoftMotion\4.x.x.0\Examples\Tutorial\PosControl.project"
Good afternoon,
To which variable of EL2521 axis I have to put EL5101 encoder value to
have an axis in close loop mode?
For the moment only moves in velocity.
thanks, regards
Ivan
Hi Ivan,
( & an enbaled DC)
check this example:
Dear Edwin,
thanks, it works.
When is necessary if I use Softmotion with raspberry realtime patch?
How could I know if my raspberry pi2 is in realtime? I am using EMLID realtime image.
Raspberry Softmotion is compatible with CNC blocks?
thanks, regards,
Ivan
check the jitter in the taskmonitor, highes prio task should be <80us I would say for Raspberry PI is good enough...
