How change Unity-ID in TCP Modbus Slave
aso3964
2018-01-26
2022-07-27
  • aso3964 - 2018-01-26
    Hello
    We are using Codesys V 3.5.10.50 on Raspberry PI model 3 to communicate with a Modbus RTU device through a Modbus TCP gateway.
    In the Slave configuration, itΒ΄s possible to define the Unity-ID address, besides the IP address and IP port of the TCP Gateway.
    However, the library only allows us to change the IP addresses and port, using the TCP-Slave.ComSettings function.
    Is there any way to swap Unity-ID via program???
    Sergio
  • john-hedges-ifm - 2019-05-31
    I would also like to know how this can be achieved.
    V3.5.11.0
    John
  • scoob
    scoob - 2022-07-27
    Did you ever find a solution to this? I am looking to perform the same thing.
