Can I run C code on a Raspberry with Codeys?
Volvo742
2018-01-17
2018-01-26
  • Volvo742 - 2018-01-17
    Hi!
    As I know, Codeys have a plug-in so the user can use C code to do code, instead of PLC code. But is that plug-in free, comes with the Raspberry Pi Codesys package or not free at all and don't come with the Raspberry Pi Codesys package?
    I going to do some system identification, math, adaptive control with the PLC.
    Because I don't think that PLC-structure text cannot do any adaptive control. That's why I think C programming is needed.
    https://books.google.se/books?id=L0m_CR ... LC&f=false m
    IMG: SkΓ€rmbild frΓ₯n 2018
    eschwellinger - 2018-01-18
    no - this is not possible/supported by Raspberry Pi at the moment.
  • hermsen
    hermsen - 2018-01-19
    This can be implemented within ST, because most PID Loops are implemented in pure ST also. Though this a bit more complex, it is definatly doable I guess.
    For some open source examples of PIDLoop implementation, take a look at the OSCAT Basic library which is free charge and downloadable from within codesys store (free account needed). They also have a website and a forum.
  • Volvo742 - 2018-01-21
    Hermsen hat geschrieben:
    Thanks! Then I have to use ST language.
    But Matrix library should also be included in Raspberry PI package.
  • hermsen
    hermsen - 2018-01-22
    Please understand that Codesys is in platform independant. So, if you have a matrix library written in pure IEC with platform dependancies, it will run in a wide variaty of targets. Stick to CAA and or Syslibs as much as possible.
  • josepmariarams - 2018-01-26
    Hi.
    There are some funtionalities with matrix in sm3_basic library.
    You can do that you want with st. If code take a lot of time you can execute this code in an assinc task.
