i have installed codesys 3.5.11.4
installed raspberry pi package 3.5.11.2
update raspberry does not show in tools.
have read simulair problems in forum
cannot install this manual in tools : custumize , because it does not show up.
the raspberry is working fine on other pc with 3.5.11.4 and same package
found the debian file in c/users/user/codesys control arm raspbery v3.5.11.2.deb.
can you help?
update raspberry is now in tools tab
found it in tab tools /customize / command icons / runtime deploy tools / update raspberry pi .
raspberry scanned and found .
on next step :package version install i get an error:
erroroutput:codesyscontrol.bin:no process found insserv: script codesyscontrol is not an executable regular file, skipped!
how can i fix this ?
Sounds like there is a corrupted installation on the Pi. First you can check the current status of the installation by clicking on "system information". If you find that there seems to be a package (half-) installed, you should try to remove it (and recheck with "system information").
If that doesn't help, you might try to remove it manually.
Start putty
Login to the pi
Type: sudo dpkg -r --purge codesyscontrol
I'm currious about your results...
Question: Do I need to do anything on the raspberry pi zero to make it findable for codesys? I cannot find the device. I did also run the three recommended update commands from terminal.
Raspberry pi plugin for codesys is installed and I created a new project. But as I mentioned, can't find the device.
Cheers / D
It depends on the kind network interface which you are using. Only if it is an onboard one CODESYS can find it automatically. So with a Zero W you might be lucky. If you use e.g. an USB network adapter, it can't be found.
But the scan feature is just for convenience. You can always just enter the IP and password manually.
Ingo Hornberger hat geschrieben:
Thanks for info. I have tried both the built-in wi-fi address (which I can vnc perfectly) and a Ethernet-Adapter. Nothing is found by typing address or scanning.
Is there a service that needs to be started on the pi?
I have not specified in codesys either which type of pi I'm using. But I reckon that should not be necessary.
You're right, it is not necessary to select the kind of Pi.
But to be honest, I am now not sure anymore in which state of the installation you are stuck. The procedure...
Download RPI Package for CODESYS
Install the Package
(restart CODESYS if this was the first time)
Open the Deploy Tool "Update Raspberry Pi" from the menu
Click on scan
Now you should see a list w/all Pis in your network. If not, enter the IP of the Pi, and its Password.
Note, that SSH needs to be enabled on the Pi!!!
If you are brave, you can press "install" now. If not, check the connection by clicking on "system information".
Create a project w/ the RPI DecDesc
Double Click on the device and scan
Actually I first thought you are stuck in step 5. This should be solved by entering the IP.
If you are stuck instep 8, please try the "system information" dialog, mentioned above. It should show you if the runtime was installed and started correctly.
There is the also a chance, that you have an IP conflict between your two networks. Or, that the netmask, which is configured on your PC and on your Pi don't match.
To be able to scan w/ CODESYS the netmask needs to be identical on both sides. Other services (like your VNC) are less strict in this respect.
If still s.th. doesn't work, I hope you can post some error messages
BR,
Ingo
1. Download RPI Package for CODESYS
2. Install the Package
3. (restart CODESYS if this was the first time)
4. Open the Deploy Tool "Update Raspberry Pi" from the menu
5. Click on scan
6. If you are brave, you can press "install" now. If not, check the connection by clicking on "system information".
7. Create a project w/ the RPI DecDesc
8. Double Click on the device and scan
BR,
Ingo
Hallo Ingo
I actually wasn't aware of all those steps But now they are done and I'm stuck on step 8.
I started the service. Or at least tries to. I also tried to specify my router as gateway to see if that helped. But it didn't.
Hope these pictures can show you where I'm stuck.
Thanks / Dan
please use 192.168.1.136 as Gateway, (the embedded CODESYS Gateway in the PI)
then it will work.
Add new Gateway with 192.168.1.136 and switch to this Gateway... then do a scan via this Gateway
then it will work.
Hello. Thank you for the tip. But still no difference. Tried with 192.168.1.136 as gateway, same port 1217.
Double-checked that the service was running on the pi, then restarted it and tried again. Same effect.
Cheers //
hm... strange, the green circle on 192.168.1.136 indicate that the Gateway and plc is running.
Could you remove some of the ethernet adapters seems you have 3?
eth0, eth1 and ?
eth0, eth1 and ?
I had an ethernet adapter. It's now gone. Rebooted device, restarted codesys. Strangely no success. Has it to do with the connection being wifi? That would disqualify pi zero though.
Cheers / Dan
Wifi in general works well. I use o Zero W myself.
Okay, so that's not it. Only thing I can think about is somewhere I read about enhance device tree. Haven't found that setting.
Cheers
Only thing i cant find is "enable device tree".
Could someone send me a simple codesys-project where I can test connection against my rpi? This to rule out any fault of mine here.
Cheers
Do you get any error when you press install? The messages from install, as well as the output which you get when you press "system info" might help.
Hello Ingo. I missed your post.
No error messages that I can see. Have added output of system info in another post.
Your imminent connection made me want to doublecheck my setup for
errors.
Created a new project with "raspbery pi SL" as device. It seems that i
earlier must have slipped during this process and chosen codesys
control win v3.
Because now i can scan and locate the rapsberry pi with gateway
setting both as "local" and with ip-address of raspberry pi.
Reply from support:
From codesys support:
ok this explains the situation
you could prevent this (not to see all plc's available on scan) by disabling the filter under Device - 'Filter network scans by target ID')
Anyway, have a nice weekend and have fun with this CODESYS PI things
can you help?
Did you restart CODESYS after installation? Sadly that's necessary after first install.
yes restarted, both raspberry and pc.
have made a little progress
Start putty
Login to the pi
logged in from other pc and it works ok
get the same errror butevrything looks ok (it controls a steppermotor )
must be something on pc because it does not find the raspberry with scan .
I like to check with your advice , but what is " start putty ??
downloaded putty
will let you know results tomorrow tomorrow
The problem is in the pc . Not the pi.
Thankx for your help
Okidoke!
But if you know more about the difference between the PCs, and have an idea what we can improve in the package, let us know...
Cheers / D
BR,
Ingo
then it will work.
Rpi Codesys Runtime info.txt [29.86 KiB]
eth0, eth1 and ?
Hi. Tried a clean install of raspbian followed by codesys runtime and a complete update of all:
Sudo Apt-get upgrade
Sudo Apt-get Dist-upgrade
Sudo Rpi-update
Cheers
still no solution?
We need to check, please use the CODESYS Store 'my question'
Hallo. Still no solution. I will go into codesys store and try to generate a question. Cheers //
Result:
errors.
control win v3.
Reply from support:
