It is currently Fri Feb 22, 2019 5:45 pm
Post new topic  Reply to topic  [ 25 posts ]  Go to page Previous 1 2
PostPosted: Sun Jan 07, 2018 4:04 pm
Edwin Schwellinger wrote:
please use 192.168.1.136 as Gateway, (the embedded CODESYS Gateway in the PI)
then it will work.
Add new Gateway with 192.168.1.136 and switch to this Gateway... then do a scan via this Gateway
Hello. Thank you for the tip. But still no difference. Tried with 192.168.1.136 as gateway, same port 1217.
Double-checked that the service was running on the pi, then restarted it and tried again. Same effect.
Cheers //Image
Rpi Codesys Runtime info.txt
PostPosted: Sun Jan 07, 2018 4:52 pm
hm... strange, the green circle on 192.168.1.136 indicate that the Gateway and plc is running.
Could you remove some of the ethernet adapters seems you have 3?
eth0, eth1 and ?
PostPosted: Sun Jan 07, 2018 5:59 pm
eth0, eth1 and ?
I had an ethernet adapter. It's now gone. Rebooted device, restarted codesys. Strangely no success. Has it to do with the connection being wifi? That would disqualify pi zero though.
Cheers / DanImage
PostPosted: Sun Jan 07, 2018 6:38 pm
Wifi in general works well. I use o Zero W myself.
PostPosted: Sun Jan 07, 2018 7:31 pm
Okay, so that's not it. Only thing I can think about is somewhere I read about enhance device tree. Haven't found that setting.
Cheers
PostPosted: Mon Jan 08, 2018 2:22 pm
Hi. Tried a clean install of raspbian followed by codesys runtime and a complete update of all:
Sudo Apt-get upgrade
Sudo Apt-get Dist-upgrade
Sudo Rpi-update
Only thing i cant find is "enable device tree".
Could someone send me a simple codesys-project where I can test connection against my rpi? This to rule out any fault of mine here.
Cheers
PostPosted: Mon Jan 08, 2018 3:30 pm
Do you get any error when you press install? The messages from install, as well as the output which you get when you press "system info" might help.
Hello Ingo. I missed your post.
No error messages that I can see. Have added output of system info in another post.Image
PostPosted: Mon Jan 08, 2018 7:07 pm
still no solution?
We need to check, please use the CODESYS Store 'my question'
PostPosted: Thu Jan 11, 2018 10:05 am
Hallo. Still no solution. I will go into codesys store and try to generate a question. Cheers //
PostPosted: Sat Jan 20, 2018 8:31 am
Result:
Your imminent connection made me want to doublecheck my setup for
errors.
Created a new project with "raspbery pi SL" as device. It seems that i
earlier must have slipped during this process and chosen codesys
control win v3.
Because now i can scan and locate the rapsberry pi with gateway
setting both as "local" and with ip-address of raspberry pi.
Reply from support:
From codesys support:
ok this explains the situation ;-)
you could prevent this (not to see all plc's available on scan) by disabling the filter under Device - 'Filter network scans by target ID')
Anyway, have a nice weekend and have fun with this CODESYS PI things ;-)
