On port 1 everythink is ok. It is work, but I have problem with port2.
I can't even open this port.
Example on screenshot in attachment.
Where is the problem ?
guess the proper solution is to add it by udev rules
would recommen to google for it.
If you add a symbloc link sure you need to add after rebooting the system..
I have a problem with serial communication.
My CODESYSControl.cfg file is:
[SysCom]
Linux.Devicefile=/dev/ttyAMA
portnum := COM.SysCom.SYS_COMPORT1;
Linux.Devicefile=/dev/ttyACM
portnum := COM.SysCom.SYS_COMPORT2;
this does not work that way.
use only this
[SysCom]Linux.Devicefile=/dev/ttyAMA
and set a symlink in Linux for
/dev/ttyACM0 -> =/dev/ttyAMA1
I used command:
sudo ln -s devttyACM0 devttyAMA1
and it is works, but after reboot AMA1 disapear, what is wrong ?
